Old 04-11-2012, 06:06 PM   #1
1badc20
disapointed
i put on front bags and when i bought the set up it came with from plates to mount the bags to....it doesnt sit any lower then my drop shocks becuase of the plates. what to do, what to do?
1badc20 is offline   Reply With Quote
Old 04-11-2012, 06:31 PM   #2
broey
Square
broey's Avatar
Re: disapointed
google search "cupping the lower control arms." also check to see if your tires are sitting on the inner fenders, they may need to come out.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 04-11-2012, 06:39 PM   #3
six-T-seven
Re: disapointed
or you could buy a set of $29 lower cups from suicidedoors/thorbros/qualityairride and cut them down to 1 1/2 - 1 5/8". it will get the truck down when aired out without all the trouble of modifying the lower A arms.
six-T-seven is offline   Reply With Quote
Old 04-11-2012, 06:42 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Re: disapointed
pictures will help us help you . As mentioned, you can cut and plate the lower control arm to make them lower...were there large cups that go under the bags to fit in the spring pocket? If so, those can/should be cut down a bit. Possibly the shocks can be limiting your travel? What size drop springs did you have before? Do you have drop spindles?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-13-2012, 09:36 AM   #5
1badc20
Re: disapointed
ill post up a picture later this weekend were having some ****ty weather where im at. the plates arent cuped they are flat with the valve cut out. im not looking to lay frame by any means just looking to ride lower with spending thousands. thanjks for your input
Old 04-13-2012, 10:13 AM   #6
vin63
It's Better With Nitro
vin63's Avatar
Re: disapointed
In many cases, the air spring size with the upper plate mounted over the upper spring cup gives the suspension a similar height as the coil spring, which means that you'll need to cup the lower control arm spring mount as mentioned earlier. This is one of the advantages of going with an aftermarket lower control arm that has a cupped lower spring mount built in. Here's a photo of my tubular arms with the air springs deflated...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-13-2012, 04:28 PM   #7
tubbedII
needs more $$$
tubbedII's Avatar
Re: disapointed
I'm sure you meant drop springs and not shocks, but you should make sure that your air bag is fully compressed when aired out and the shock isn't holding you up from going lower. I never had inner fenders in, but from the looks of it with my 22's the fenders would definitely held my ride up too. Do you have drop spindles?
I have a set up cupped lca's that I'm not going to use. I bought them off the board and decided against it since right now it sits level with the rear air'd out...let me know if you're interested. If you're close to Sac, you could pick them up cuz the darn things are heavy...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 04-13-2012, 07:35 PM   #8
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: disapointed
Originally Posted by vin63 View Post
[COLOR="Navy"]
where are the tie rods from?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-14-2012, 10:06 AM   #9
vin63
vin63's Avatar
Re: disapointed
The tie rods are just OE replacements...are you referring to the adjuster? I made them from steel bar stock many years ago, I copied the set on my friend's street rod. I believe you can get nicer aluminum ones from CPP...at least I saw them on display at the last CPP cruise.
