Old 04-15-2012, 06:11 PM   #1
100mph
Push Button Start - in factory igntion
If anyone is interested I found a great push button start system that fits in the factory ignition bezel.
Name:  finished install.jpg
and its a really simple install too.
Just remove the factory ignition from the dash and break off the connector
Name:  breaking connector off.jpg
Then you just need to file down a ridge inside the housing so the start button plug will fit through it
Name:  file out igntion housing.jpg
Then you just cut the plug off the factory wiring harness
Name:  factory wiring connector.jpg
And from there you simply match the colored wires with the supplied harness - I found looping the wires through the ignition hole a lot easier for soldering (and make sure you have a high wattage iron - these wires are heavy gauge!) And then one wire to the brake switch
Name:  pull wires through hole to solder.jpg
The company that make these systems is Digital Guard Dawg and I have to give them a lot of credit for coming up with a button solution that worked so well in this truck. At first I was trying to find a solution that would fit in the 2" ignition hole in the dash (picture above) but they found a button (Lexus) that fit right into the factory bezel.
You could use a little tape or adhesive but its pretty much just a nice snug press fit into the bezel and in my opinion it looks great!
Here's their website if anyone is interested - just make sure you get the new Lexus slim button
http://www.digitalguarddawg.com/2GOKEYLESS1.html
100mph is offline   Reply With Quote
Old 04-15-2012, 07:00 PM   #2
danny6892002
danny6892002's Avatar
Re: Push Button Start - in factory igntion
How much?
danny6892002 is offline   Reply With Quote
Old 04-15-2012, 07:30 PM   #3
Gobbles
Gobbles's Avatar
I found the slim pack on the site for 70. Looks nifty, the rfid kits are kind of excessive but the plain start is pretty neat
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 04-15-2012, 07:31 PM   #4
Devil Pup
Devil Pup's Avatar
Thats really cool. Would love to do this, looks like it belongs in the ignition bezel
Devil Pup is offline   Reply With Quote
Old 04-15-2012, 07:41 PM   #5
YBNORML
YBNORML's Avatar
Totally cool!
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 04-15-2012, 07:54 PM   #6
100mph
Originally Posted by danny6892002 View Post
How much?
$499 plus $69 for the button... not cheap but well built and does also add a level of security with the rfid tags.
Works flawlessly and you can also add doors, windows etc to the system too
Old 04-15-2012, 09:30 PM   #7
CG
BlahBlahBlah
Looks cool, but now all you have to do is push the button to start your truck? Or is there some other sort of safety feature that cuts off the power?
Old 04-15-2012, 09:42 PM   #8
502ms
502ms's Avatar
I'd like to know more on this, too
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 04-15-2012, 11:04 PM   #9
100mph
Its just like a newer cars keyless push button start - it comes with an RFID keyfob - when the keyfob is close to the truck the button lights up, put your foot on the brake and push the button to crank the motor, hold it till it starts. Of course it doesn't do anything when the keyfob is away from the truck
Then to stop the motor you have to put your foot on the brake and hold the button for a few seconds. It's also wired through the neutral safety switch - pretty much just 5 wires to install it and they even used GM color coding so you just match up the colors.
It has all kinds of modes too - i haven't played with it but I believe you can have it leave the accessories on but lock the ignition (for car shows). It also has a manual mode where you have to push a lock/unlock button to 'activate' the system.
Its well thought out but super simple
Old 04-15-2012, 11:12 PM   #10
100mph
I'm clearly not a photographer but here's a straight on shot
Old 04-15-2012, 11:33 PM   #11
MrSchaeferPants
MrSchaeferPants's Avatar
Very nice. Though I imagine a relay could be hooked up so you don't have to worry about the heat issue, with all that power running through the button? Perhaps a future project
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline   Reply With Quote
Old 04-16-2012, 12:54 AM   #12
CG
BlahBlahBlah
Well its a pretty neat set up. I don't have one of them there new fancy pants cars (lol) so I had no idea how those push buttons worked. Thanks for explaining it!
Old 04-16-2012, 12:58 AM   #13
PAWS 72
PAWS 72's Avatar
Why worry about heat.Honda and Nissan already uses them in there cars.Don't misplace the fob though.Ask my wife.
PAWS 72 is offline   Reply With Quote
Old 04-16-2012, 09:47 AM   #14
68gmsee
Active Member
68gmsee's Avatar
The security issue had me confused also. I've only seen these type of ignition start systems on commercials.
68gmsee is offline   Reply With Quote
Old 04-16-2012, 10:05 AM   #15
67c10rustbuket
67c10rustbuket's Avatar
That is cool ! Thanks for sharing. I guess I would have to hack my 67 dash though since 67 has a one year only smaller ign bezel. RFID would be awesome.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-16-2012, 10:12 AM   #16
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Had one of those type systems in a Murano I used to have. Bought the car new and traded it after 11 months of pure pain and misery. One of the major problems we had with that keyless system is the jamming of or loss of the signals between the car and the RFID keyfob unit. More than once the car went into "shut down mode" while driving at highway speeds because of loss of signal between the RFID and the car. And this happened when both my wife and I were in the car with BOTH RFID keyfob units in the car with us.
Cool system in theory and looks great in your truck, but be careful in case you run into the same situation as I encountered.
Al
'69 GMC 2500 Custom Camper
'69 Chevy C10 396BB LWB
alsriv2 is offline   Reply With Quote
Old 04-16-2012, 10:36 AM   #17
100mph
No worries about heat... the starter doesn't actually run through the button - the button just controls their 'box' that I assume has all the relays etc and handle the high current
Old 04-16-2012, 10:40 AM   #18
100mph
Al
I suppose the good and bad of it is that once you start the truck with the rfid fob in range it continues to run even if you walk away with the FOB - all the fob does is 'unlock' the igntion so I don't think there's any need to worry but I can imagine that would have been pretty scary when your car just shut down!
Oh and they also include a manual override should you lose the fob - you get a pass code card and you use a button wired to the main control box to 'type' in your code to override the rfid (in case you lose it, battery dies etc).
Old 04-16-2012, 11:53 AM   #19
alsriv2
alsriv2's Avatar
Sounds like this system has worked thru the kinks of the Nissan system of the 2005 generation. My Murano's system was set up so that when the keyfob was away from the car for a preset distance (car and kfob not able to talk)for a set amount of time, the car would shut off as a anti-theft/security feature. Sounds great until you are driving at 70mph and the car goes into shut down mode because the kfob and the 'system' stop talking to each other.
Al
Old 01-11-2013, 09:37 PM   #20
smoky02
Location: Sunny, Florida, some might call it South Alabama
Was the lexus button the only one or size that worked with our key hole? I was actually thinking the S2000 button would look perfect on my dash.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 01-12-2013, 09:20 PM   #21
mvesr
I didn't see one for $70.00
Mika
mvesr is offline   Reply With Quote
Old 01-12-2013, 10:20 PM   #22
Scott>72-GMC
Scott>72-GMC's Avatar
Being a quadriplegic working on my truck I've often wondered what I'm going to do about turning my ignition against popular belief being a quadriplegic doesn't mean I can't move my arms just that I don't have full function of my arms lack of triceps and no finger movement But this looks like the perfect solution to turning the key!!!
Scott>72-GMC is offline   Reply With Quote
Old 01-13-2013, 02:47 AM   #23
Z10
Z10's Avatar
Al
I have a similar system in my 06 Z06. If I forget and leave my iPhone in my pocket with the fob, it will jam the signal. Did you happen to have a phone in your pocket with the fob?
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 01-13-2013, 03:25 AM   #24
SCHRUMGMC
SCHRUMGMC's Avatar
I would rather have a Key
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 01-13-2013, 05:38 AM   #25
huahuamick
huahuamick is offline   Reply With Quote
