Old 04-17-2012, 01:27 PM   #1
HotRodScottsdale
HotRodScottsdale's Avatar
Carb size??
So I showed my motor to a buddy and he took one look and asked what size my carb is cause he said "it looks ****ing big"
Is there away to find out what size it is by codes on it or how can I do that, it's an edelbrock aftermarket but it came with truck and I have no specs on it and I'm always looking for more to say when people say "what's it got?" lol
HotRodScottsdale is offline   Reply With Quote
Old 04-17-2012, 02:02 PM   #2
wilkin250r
wilkin250r's Avatar
Re: Carb size??
This is from memory, so I could be wrong. But I think if you're staring at the carb, the bottom left corner should have a number on it. That number will tell you the particular model, and from there you can look up the specs.
The most common are probably going to be 1405 and 1406, both are 600CFM carbs. I think there are some small internal jetting differences, but the most obvious would be the 1406 has an electric choke.
A 1407 is a little bigger at 750cfm.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 04-17-2012, 02:06 PM   #3
HotRodScottsdale
Re: Carb size??
Ahhh ok yeah mine says 1406 0447 right there, it says weber on the side too, dose that mean anything, I also got the # from the bottom of it too 1-28-7-20-1, any info I can get would be awesome
Old 04-17-2012, 02:07 PM   #4
jrcaprai
Re: Carb size??
look for a Part number similar to 1406 ?
jrcaprai is offline   Reply With Quote
Old 04-17-2012, 02:14 PM   #5
HotRodScottsdale
Re: Carb size??
Some pics for lookers
Old 04-17-2012, 02:16 PM   #6
Your41Plague12
Your41Plague12's Avatar
Re: Carb size??
Weber made the castings for Edelbrock carbs. You have a standard 1406, just order parts for that.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 04-17-2012, 02:23 PM   #7
HotRodScottsdale
Re: Carb size??
Sweet thank you, I plan on cleaning up everything under the hood so the more I can learn the better
