5 lug swap question
I recently got a rolling 71 C10 frame. I plan on swapping all the 5 lug parts and discs on to my 68. I plan on using the a-arms, spindles, discs, etc and just the rear end. Is that a good plan or should I use other parts too? Tie rods, cross-member...?
Re: 5 lug swap question
X2, thanks for asking.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord......... |
Junior Member
When we wanted to go to 5 lugs on my '69 swb frame we used all the parts off of a '71 donor frame.
We used the whole front cradle with suspension and steering along with the reared. It was an easy conversion.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Restoration Virgin!
just unbolt the front cross member and swap it out.....that way you get everything with having to piecemeal it.....on the rear end, remember that it is wider than the 68 rear end....so if you have wheel selected make sure they will fit your application....if you want to stick to the 68 rear, ECE makes the 5 lug conversion axles....Have fun with it and enjoy your build!
Also, take some time and read through this thread for your conversion....http://67-72chevytrucks.com/vboard/s...d.php?t=444823
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
