Optional factory ac in 1970?
My truck has factory optional ac on it. I need to replace the hoses inside the cab? Can I assume the hoses in my truck are the same that came with factory ac?
Posted via Mobile Device |
Re: Optional factory ac in 1970?
I have not seen the optional AC system but I have to believe that the AC hoses are different in that all factory AC hoses are on the outside of the firewall and do not go inside the cab.
New hoses can be made up if yours are bad. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 05-03-2012 at 08:38 AM. Reason: wording |
I'm guessing that the duct hoses are different from add on AC vs factory AC. You'll have to measure yours and try to match them up, should not be had to find them.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Not sure what the difference between "factory" and "factory optional". If you meant dealer-installed or aftermarket, it's most likely different. If it's below the dash, it's certainly different.
That said, the tube kits are cheap enough that if you check the diameters you might still be able to buy a kit and make them work.
