Old 05-11-2012, 09:18 PM   #1
mikewarme
Radiator help / Fan shroud
Somebody must have run into this issue. I have a new radiator CU369.
My truck is a 69 3/4 ton with a 396. I have the big block correct fan shroud. Radiator seems 1" too high because shroud will not reach upper and lower mounting points. I even took the rubber pads out and still too high. The top brackets seem to be at a touch of an upward angle indicating an issue. The radiator is the same size as the one I took out but there was not a shroud when I bought the truck. So if i attach the shroud to the upper brackets, it sits too high and cant get lower screws in. Also fan blades rubs bottom of shroud. Somebody else has to have run into this before.
Big block guys here is the question if you're truck has a shroud.....
1. What is the height of your radiator?
2. What is the diameter of your fan blade?
3. Any Pictures??
Really appreciate any input
mikewarme is offline   Reply With Quote
Old 05-12-2012, 07:57 AM   #2
JimKshortstep4x4
Re: Radiator help / Fan shroud
My son does not have the big block truck anymore but it used clips on the bottom instead of the screws. The clips have a little more leeway.
Is the fan centered when the shroud is attached at the top?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-12-2012, 12:34 PM   #3
mikewarme
Jim
I have the clips as well but if you attach it to the top than the shroud just misses the bottom to short clips wont reach. No Fan seems too low. But that still would not solve the shroud from attaching at top and bottom.
Aarrrrrrrrr
Old 04-14-2013, 02:37 PM   #4
Bruser
I have the same problem with my sb350. did you ever figure out the source of the problem? How did you solve your issue? Been looking at threads but haven't found an answer yet
Bruser is offline   Reply With Quote
Old 04-14-2013, 05:46 PM   #5
Shyguy
Junior Member
Shyguy's Avatar
I have the same problem with the 454 in my '67. The enginve sets down about an inch too low keeping the shroud from being centered with the fan.
I have a piece of metal angle that I am going to lay down the back of the radiator and mount to the radiator hold-downs. Then I can mount the shroud where it needs to be on the piece of angle. I think the angle is right at 30 inches long, the top part that will go over the to radiator hold-downs is about 6" and the part that will go down the back of the radiator is about 4 inches. The angle is about 1/8 inch thick.
Hope this helps.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-14-2013, 06:32 PM   #6
Gene
Gene's Avatar
Have the same problem with my small block 350. I have broke both tabs on my radiator shroud and I had to put extensions on.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 04-14-2013, 11:16 PM   #7
Bruser
Good idea shyguy, I've got to come up with something also. Still doesn't answer the question as to what is the cause of this problem. When I got my truck the top two mounting tabs were broken off the shroud and it had a new radiator so I don't know what it looked like originally. Now when I am putting it all back together the top mounts are angled up to the rear so doesn't seem right.
