05-28-2012, 04:49 PM | #1 |
Who has a TH350 bolted to a '99 LQ4
Not trying to reinvent the wheel. Just want to know what parts I need to make it work.
05-28-2012, 05:47 PM | #2 |
Re: Who has a TH350 bolted to a '99 LQ4
1999 & 2000 LQ4's have a longer crank end than other LS engines, This takes care of the crank spacing, Do you have the flexplate? If not buy a LQ4 flexplate. You might have to slot the torque converter bolt holes in the flexplate.
05-28-2012, 07:09 PM | #3 |
So any flexplate will do?
05-28-2012, 07:10 PM | #4 |
I have an extra 5.3 flexplate gathering dust.
05-28-2012, 07:37 PM | #5 |
You need a LQ4 specific flexplate.
NO other LS flexplate will work. 1999 & 2000 LQ4's are a little different animals. You do have cast iron heads,,right? |
05-29-2012, 10:50 AM | #6 |
Indeed I do have cast iron heads. I will scour the junkyard today for a '99-00 specific flexplate. I see you have a Duramax, EfiLive on it? Have an '05 Cummins myself, unfortunately efilive is only available for '06+
05-29-2012, 11:39 AM | #7 |
A guy with a truck
Does not need to be 99-00 specific; you are looking for the flat flexplate, no dish. Like stated above, you'll need to slightly egg the converter holes to accommodate the difference between metric/standard bolt circles. Does the TH350 use a kickdown cable?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-30-2012, 08:11 AM | #8 | |
05-30-2012, 11:24 PM | #9 |
A guy with a truck
So, that's another consideration, as well as the dipstick, which mounts to the 'missing' bellhousing bolt.
05-31-2012, 06:41 PM | #10 |
06-02-2012, 12:11 PM | #11 |
06-13-2012, 10:36 AM | #12 |
None?
06-13-2012, 11:18 AM | #13 |
A guy with a truck
Bowtie overdrives has a kit for a TV cable for 700r4/2004r that may be able to be adapted for the kickdown. I've seen people attach a pipe clamp to the head for the dipstick, or buy an aftermarket, ala Lokar. I think I will try to use some sort of nutsert. Do not drill the block! There is a water jacket there...
06-13-2012, 02:04 PM | #14 |
Thanks gringo
06-13-2012, 03:02 PM | #15 |
I'm running a 350 behind a 5.3 works ok I had one out of an express van with 80e so had the proper flexplate and spacer if you have a 60e the flexplate will not work as I was told I'm in the process of swapping in a 700 with the bowtie overdrive kit
Posted via Mobile Device |
06-13-2012, 05:47 PM | #16 |
Where is the 80E?
06-13-2012, 08:31 PM | #17 |
Truck and auto performance nut
GM 4 speed electronic overdrive version of the turbo400.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
06-13-2012, 09:56 PM | #18 |
Not "what", but "where" is it...lol. Figured he would have bought the trans to go along with the motor.
06-13-2012, 10:25 PM | #19 |
Oooooooooooooops!
06-16-2012, 04:39 PM | #20 |
How the heck do I get the last bolts at the top of the trans out? Do I have to drop the trans first?
06-16-2012, 06:25 PM | #21 |
A guy with a truck
What truck is it in? I've had luck pulling them from above in 99-up trucks. Just crawl up on top of the engine and reach behind with an open end wrench...
06-16-2012, 08:07 PM | #22 |
Its an '84 C10 Gringo. I haven't installed the LQ4 yet, just a sbc\th350 combo.
