Old 05-29-2012, 01:43 AM   #1
mexlokote
mexlokote's Avatar
1963 rpm install help,,
i will like to know how to install an RPM on my truck, just the wiring part,
thanks
mexlokote is offline   Reply With Quote
Old 05-29-2012, 10:43 AM   #2
1963c-10
1963c-10's Avatar
Re: 1963 rpm install help,,
What is a RPM?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-29-2012, 11:02 AM   #3
mexlokote
mexlokote's Avatar
rpm guage
Old 05-29-2012, 11:16 AM   #4
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Originally Posted by mexlokote View Post
rpm guage
AKA tachometer or "tach"
mexlokote, basically you're going to need a wire from a key-switch-on power source, a ground wire and a signal wire. if you want the tach to light up when you turn the lights on you'll also need a wire from the light switch.
what tach are you using?
do you have points/coil or HEI?
Larry
fleetsidelarry is offline   Reply With Quote
Old 05-29-2012, 11:43 AM   #5
1963c-10
1963c-10's Avatar
Ahhh.... if he had said Tachometer or tach I would have got it.
Old 12-12-2013, 09:14 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by 1963c-10 View Post
What is a RPM?
Revolutions Per Minute
66 C20 Service Truck:
Old 12-13-2013, 02:47 AM   #7
BigDan3131
BigDan3131's Avatar
LMFAO!!!!!!!
Doesn't anyone know how to read a book anymore???
What's a book right?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 12-13-2013, 10:00 AM   #8
1963c-10
1963c-10's Avatar
I know what RPM means....just never heard of a part called RPM to install.
Old 12-13-2013, 12:53 PM   #9
LostMy65
LostMy65's Avatar
i know what rpm means....just never heard of a part called rpm to install.
I figured that.
Old 12-13-2013, 12:59 PM   #10
1963c-10
1963c-10's Avatar
