Old 05-16-2003, 12:46 PM   #1
chaptr2
chaptr2's Avatar
Angry Need help getting 2wd Manual Trans cross member out.
I'm taking my 4 speed out and putting in a new th400. Last night I was trying to get the 4 speed cross member out, but had a hard time. This should come out just by using a BFH, but I want to know if there was a trick to it. IE pound the left side of the cross member forward and the right side towards the back.
Can anyone offer any real good advice besides cutting this?
This is only my opinion and it is subject to change.
70 GMC Short box stepside Blown 388 Stroker
72 K/5 Blazer 350/SM465/205
chaptr2 is offline   Reply With Quote
Old 05-16-2003, 01:14 PM   #2
Not to offend the intelligence, but did you cut out all the rivets holding it in place. If I remember, mine is held in with 3 rivets on each side. Once those are outI think it just falls out, nuless someone welded it in in the past.
Old 05-16-2003, 01:15 PM   #3
chaptr2
chaptr2's Avatar
Yes I did take the rivets out and no the cross member doesn't fall out. I wish it did but it doesn't.
Sorry that comment kind of stung a little, but I understand what kind of point you were trying to make.
Old 05-16-2003, 02:33 PM   #4
biglou55
put a hydraulic bottle jack and a piece of 4/4 between the frame rails and spread the frame a fraction . it worked for me good luck.
Certifiably crazy person
biglou55 is offline   Reply With Quote
Old 05-16-2003, 04:25 PM   #5
cruzn72
I just took out my cross member. I don't know if it makes a difference, but mine is an auto. I had to use a BFH and walk it back like you said, hit left then right, etc. I like the spread the frame idea posted above.
http://photos.yahoo.com/cruzn72@pacbell.net
cruzn72 is offline   Reply With Quote
Old 05-16-2003, 05:27 PM   #6
chaptr2
chaptr2's Avatar
The auto was much easier than this stick. If I can't walk it back tonight and find the sweet spot than I will spread the frame. Thanks guys for your help...
Chap
