Old 06-23-2012, 10:23 PM   #1
sox8145
drop spindles
Whats up guys i have a problem with my 4/6 belltech drop kit. I cant find the right berrings for the spindles they r a 3''belltech drop and for 1'' rotors part # 3200 ive been to all the part stores and no luck i got some that fit but when i put the rotor on the spindle it wiggles alot. ive serched the forum and havent found a clear explenation on what i should do has anyone had this problem if so what should i do. Oh and my truck is an 85 chevy swb 1/2 ton
sox8145 is offline   Reply With Quote
Old 06-24-2012, 08:23 AM   #2
J Knight
J Knight's Avatar
Re: drop spindles
It sounds like you might actually have a 1.25in rotors needing the larger bearings, only the inner bearing is different between 1in and 1.25in rotors. You might want to double check the thickness.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 06-24-2012, 11:35 AM   #3
sox8145
Re: drop spindles
I have the right thckness in rotors 1'' i also tried some 1 1/4'' roters and they were to big
Old 06-24-2012, 12:26 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: drop spindles
I have 3" Belltech #3200 spindles on my truck project with 1" rotors.
I got the bearings at my local parts store.
Keith
Convert to disc brakes.
Old 06-24-2012, 12:30 PM   #5
lolife99
lolife99's Avatar
Re: drop spindles
The inner bearing is a A6 bearing for the light duty rotors.
The outer bearing should be A3.
(the HD 1-1/4" rotors take A5 inners and A3 outers)
Keith
Old 06-24-2012, 12:42 PM   #6
sox8145
Re: drop spindles
ok thanks man im going to the parts store right now
Old 06-24-2012, 01:36 PM   #7
sox8145
Re: drop spindles
I Went to get the bearings and thoes woint work either they fit the rotor but they dont fit the shaft of the spindel they need to be a little smaller the rotor has to much play and wiggles alot
Old 06-24-2012, 01:39 PM   #8
J Knight
J Knight's Avatar
Re: drop spindles
Does it do this on both spindles. Just trying to see if the spindle might be defective.
John
Old 06-24-2012, 01:47 PM   #9
sox8145
Re: drop spindles
Yes it does i tried to call belltech but they r closed till tomorrow
Old 06-24-2012, 01:52 PM   #10
J Knight
J Knight's Avatar
Re: drop spindles
Wich ever parts fit your stock spindles should fit perfectly on the drop spindles. It must be the wrong spindles or they are possibly defective.
John
Old 06-24-2012, 01:59 PM   #11
sox8145
Re: drop spindles
yeah thats what i was thinking
Old 06-24-2012, 03:06 PM   #12
lolife99
lolife99's Avatar
Re: drop spindles
The last set of Belltech spindles were boxed wrong.
But your spindles should have a number cast into them.
Theyre not 3100 or 3120 spindles are they?
Keith
Old 06-24-2012, 03:48 PM   #13
sox8145
Re: drop spindles
yeah its on there the number is 3200-302
