Old 03-26-2002, 06:08 PM   #1
chevy55
Post Bolt Pattern
I'm looking to buy a bell housing from a 67-72 pickup, does the 4 speed and 3 speed have the same bolt pattern?
1955 Chevy Shortbed Stepside 2nd Series.
http://community.webshots.com/user/chevy55truck
chevy55 is offline   Reply With Quote
Old 03-26-2002, 07:05 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
all chevy 4.3L and 230 and up are same bellhousing pattern after 1954
happy swapping
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
r68c30@hotmail.com
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 03-27-2002, 09:35 AM   #3
Blazer1970
Blazer1970's Avatar
Post
Interface to the engine is the same. Interface to the tranny is different for 3 and 4 speed.
Blazer1970 is offline   Reply With Quote
Old 03-27-2002, 09:56 AM   #4
69 longhorn
Post
From 67-72 ,you should have the same bolt pattern on both sides of the bell. There will be a difference in the bell pilot hole for the trans.....68-up will be 5 1/8",& 67 & older will be 4 11/16". If you have A car trans(3 or 4 spd),or an sm420 4spd,you will need the small hole bell. the ch 465 4spd,& the later 68 up truck 3 spds will take the large hole bell. On the saginaw trannys(7 bolt side cover),you can swap the throw out collar from car to truck,& use either bell. Good luck.....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
