67cheby
![]() Join Date: Sep 2008
I can not get my ignition switch out !
I have tried all of the paper clip tricks and everything to get my iginition switch out of my 67 ,it wont budge, any help or ideas ?
TILT COLUMN GURU
![]() Join Date: Dec 2006
Re: I can not get my ignition switch out !
You must have in accessory position to push release then turn counter clockwise.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
67cheby
well just called my bodyman , he has tried everything HE GOT IT OUT ! on a totally non related subject....i need to buy an iginition for a 67 ...LOL
#4 | |
The Older Generation
When you have the pin depressed turn the cylinder further counter clockwise as Kev said. When it turns past the pin you will have to remove the paper clip or it will bind. Turn the cylinder as far as it will go and it should pull out. You may have to wiggle it a little. Sometimes they can be stubborn... ![]() LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-17-2012 at 11:20 PM. |
![]() Join Date: May 2012
what they said is how it works....then unscrew the chrome ring on front from ign. switch on back side....
I struggled with this for an hour before I clamped a small vice grip on the key to get more leverage to turn it backwards it was kinda tough,also i had to use a flashlight too see the little shiney plunger through the hole cause it didnt quite line up right when in the acc. position
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
