Old 07-22-2012, 02:24 PM   #1
smartass12
smartass12's Avatar
A little HELP!! from dropmember guys please.
I obvioustly screwed things up..look where my dif lines up in my notch when the trailing arms are installed. Can i just move the trailing arm crossmember forward to fix this or am i screwed??
second bit of help needed. I cant seem to find hardware in my kit to mount the upper and lower control arms. this is all the hardware i have left other than miscellaneous nuts and bolts (nothing i have left seems correct for installation). Does the uppers mount (flat side if pivot, for lack of better words) dirrectly to dropmember with just bolt/nut? Also was i to use something off my old lower control arms to mount the new ones?? the rod/nuts in nates instructions are no where to be found and wasnt sure i had to use something off my old setup?
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
