Old 08-03-2012, 12:44 AM   #1
KrazyRay
KrazyRay's Avatar
4:10 Eaton
I have a non posi eaton pulled from a 69 3/4 ton Chevy. It looks to be in good shape. 41 teeth on the ring gear and 10 teeth on the pinion gear.
$150 plus shipping. If the shipping is more than $100 to the east coast guys, I will pick up the difference. wpecina is first up.
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 08-03-2012, 06:16 AM   #2
tow guys
tow guys's Avatar
Re: 4:10 Eaton
Interested pending fitment. I think I have an HO72. Not positive though. It's in a 1 ton dually. If it is, will this fit?
Thanks,
Tony
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431
Member of the 1-Ton Club!
http://www.eastcoastcarandtruck.org
tow guys is offline   Reply With Quote
Old 08-03-2012, 11:17 AM   #3
KrazyRay
KrazyRay's Avatar
Re: 4:10 Eaton
I don't know for sure. There are some members that know the compatibilities.
Old 08-03-2012, 04:58 PM   #4
tow guys
tow guys's Avatar
Re: 4:10 Eaton
If it is confirmed that this will in fact work in my truck I am interested pending a shipping quote to zip 08721 in New Jersey. Let's figure out if it works first before you waste any time on that quote though.
You could also quote the shipping to my business address in Freehold NJ zip 07728. We have a loading dock there. Might be easier to unload it.
Thanks,
Tony
Old 08-04-2012, 08:48 AM   #5
wpecina
Re: 4:10 Eaton
Thanks,
Ray
Thanks Ray - I am checking mine today to be sure it is a 4:57 - if yes - I want your 4:11.
Wayne
wpecina is offline   Reply With Quote
Old 08-04-2012, 11:24 AM   #6
pumpkin
pumpkin's Avatar
Re: 4:10 Eaton
They do interchange. From the best that I can find an HO72 has the load bolt for the ring gear, and the HO52 does not. That seems to be the only differance I can find between the two diffs.
pumpkin is offline   Reply With Quote
Old 08-04-2012, 12:43 PM   #7
KrazyRay
KrazyRay's Avatar
Re: 4:10 Eaton
Wayne...Let me know when you find out. I can ship Monday.
Tony...They are compatible with the HO72. Member Jessechop has done the swap. pummkin...thanks!
Thanks,
Ray
Old 08-04-2012, 02:54 PM   #8
wpecina
Re: 4:10 Eaton
Ray,
I had about 22.2 turns of the driveshaft for 10 turns of one rear wheel. Per another member that yields about a 4:44 ratio - can I assume it is a 4:57 from this?
Thanks,
Wayne
Old 08-04-2012, 03:00 PM   #9
KrazyRay
KrazyRay's Avatar
Re: 4:10 Eaton
Wayne, Its most likely a 4:57. You can pull the cover and look for the stamping to be sure.
Old 08-04-2012, 04:27 PM   #10
tow guys
tow guys's Avatar
Re: 4:10 Eaton
What about axle spline count? Were there different axles for the 3/4 ton and 1 ton rears?
Also, coming from an axle ratio in the high 500's, and a top speed of about 55mph, what can I expect out of a 4:10 swap?
Old 08-04-2012, 11:43 PM   #11
KrazyRay
KrazyRay's Avatar
Re: 4:10 Eaton
There are 17 splines on the axles. I would think you could gain 20% top speed if yours is in the 5's.
Old 08-05-2012, 10:11 PM   #12
wpecina
Re: 4:10 Eaton
Ray,
I hope to pull the cover Mon. evening.
Thanks,
Wayne
Old 08-06-2012, 10:10 PM   #13
wpecina
Re: 4:10 Eaton
RAY - i PULLED THE COVER - HERE ARE ALL THE NUMBERS:
3682104
GM 7-32
6 54
The 6 54 is stamped as your 10 41 in the picture you sent.
Old 08-06-2012, 10:11 PM   #14
wpecina
Re: 4:10 Eaton
3682104
GM 7-32
6 54
Wayne
Old 08-06-2012, 10:13 PM   #15
wpecina
Re: 4:10 Eaton
Originally Posted by wpecina View Post
Ray,
Thanks,
Wayne
Sorry- the 7-32 looks like the 10-41 in your picdture.
My bad
so what is a 7-32??
Old 08-06-2012, 10:34 PM   #16
wpecina
Re: 4:10 Eaton
Thanks,
Ray
Ray - 32/7 =4.57 DAH!!
I want yours - how do you want to get paid?
Wayne
Old 08-07-2012, 12:47 AM   #17
KrazyRay
KrazyRay's Avatar
Re: 4:10 Eaton
pm sent
Old 09-08-2018, 10:07 PM   #18
racenhogs
Re: 4:10 Eaton
If anyone knows where I can find a center section for my 3600 it would be awesome...please help!
racenhogs is offline   Reply With Quote
Old 09-09-2018, 12:48 AM   #19
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: 4:10 Eaton
Can't tell you any specific differences between HO72 and HO52 (axles? brakes? splines?).
This much I know.... All HO72s have the load bolt.... Some HO52s do have the load bolt and some do not.
Before anyone mentions it.... yeah, I realize this is an old thread. Just taking the opportunity to share a snippet of information.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 09-12-2018, 11:36 PM   #20
Stagerunner
Re: 4:10 Eaton
Stocker is correct. Early ho52 did not have load bolt late ones did. Pumpkins do interchange. Real difference is ho72 used bigger brakes since mostly used in 1 ton trucks
Stagerunner is offline   Reply With Quote
Old 09-13-2018, 06:38 AM   #21
1968k20
1968k20's Avatar
Re: 4:10 Eaton
I've got an ho 52/72 sitting in my garage. I'll look at it late afternoon for you.
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 09-13-2018, 10:01 AM   #22
racenhogs
Re: 4:10 Eaton
Buddy...that would be great if you check and see if you have a 4.10 gear set in an HO52/72 carrier...please let me know.
R/Charlie
Old 09-13-2018, 11:52 AM   #23
Killer Bee
Killer Bee's Avatar
Re: 4:10 Eaton
hey Lisa, if you have gears for Charlie, I'll take the locker off your hands if it has one
Old 09-13-2018, 11:54 AM   #24
Killer Bee
Killer Bee's Avatar
Re: 4:10 Eaton
and btw, the 4.10 should be stamped on the ring gear expressed in tooth count..
Old 09-13-2018, 02:19 PM   #25
1968k20
1968k20's Avatar
Re: 4:10 Eaton
I'll look into it tonight, KB! Thank you
