Old 03-27-2002, 09:57 AM   #1
Frank_Zeller
Frank_Zeller's Avatar
Post 1.6 ratio rocker arms
Any of you guys using 1.6 ratios stamped steel with or without the roller tip rocker arms? Any problems? What ones did you buy?
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 03-27-2002, 10:16 AM   #2
69 longhorn
Post
I have run several sets of Comp cams Magnum roller tips,but a 1.52 ratio,& havent had any trouble. I have been told that if you are over .480 lift& heavy springs,the stock type stamped rockers are not the way to go. Good luck......69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-27-2002, 10:19 AM   #3
Frank_Zeller
Post
Just called comp cams........they said you have to relieve the push rod holes for clearance with the 1.6 ratio rocker arms..Darn
Austin-Texas
