08-13-2012, 02:31 AM | #1 |
Moderator
Small Speedwarning/Tach parts for sale
I have some various speedwarning parts and a back tach tin for sale.
1. Speedwarning back tin. I removed the brass lug and painted it inside and out. I was going to use this as a template to drill the two holes on my tach tin listed below, and reattach the lug to it. Tin and lug are $45 Shipped. 2. Tach back tin. Painted inside and out. $45 Shipped. 3. Four speedwarning cable nuts. $10 Shipped each. 4. OEM Speedwarning buzzer. From an early Buick. Only difference is that it does not have a mounting bracket like the truck one. It plugs right into a truck harness. It is tested and works perfectly. $75 Shipped. 5. Speedwarning input gears. The blue plastic one is OEM. The brass one is identical and was used in later model speedwarnings...this one will never break $20 Shipped each. 6. OEM Cruise control/turn signal lever. Similar to the chrome one used in our trucks...but NOT factory correct. $25 Shipped. 7. New Chrome gauge bezel. $35 Shipped.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-13-2012, 02:32 AM | #2 |
Moderator
Re: Small Speedwarning/Tach parts for sale
new bezel
08-13-2012, 02:47 AM | #3 |
I'll take the buzzer
Posted via Mobile Device |
08-13-2012, 03:41 AM | #4 |
Always on the hunt...
I will take the blue OEM gear, I will also take the brass one if it is dimensionally consistent with the other pictured blue gear. Its hard to tell in your picture, does the brass one have the lip at the back edge of gear (see arrow in pic)? Pm me your payment info and I will get you paid. Thanks, Mel
08-13-2012, 05:14 AM | #5 |
I will take both back tins and best speed warning cable nut.
69 Custom 10, 350, 350, PS, PB GG Uncle bought new in 69 Fully restored in 92 |
08-13-2012, 12:47 PM | #6 |
Missed out on your sale of the sw tin, but have a question for you...
How were you able to separate the brass pin into two pieces?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
08-13-2012, 12:53 PM | #7 | |
Moderator
08-13-2012, 12:59 PM | #8 |
Moderator
The brass pin is one piece that has a small retainer nut (for lack of a better term) pressed on from the inside.
08-13-2012, 01:09 PM | #9 |
Thank you for the explanation, i didnt want to try it without some advise
08-13-2012, 08:28 PM | #10 | |
