What shocks to use with flip kit?
I found this flip kit on ebay for 37 bucks. Its just basically the plate that goes between the axle and leaf springs. I just read on c10forums that some guy use c30 front shocks on his c10 and it works good. Anyone heard about this before? here's pics...
am on a budget so cant afford drop shocks. Im even considering air shocks but those sound expensive. |
Re: What shocks to use with flip kit?
You already have your axle flipped on top of the leaf springs, and looks like it was done by welding a leaf spring axle bracket to the axle. You won't need those brackets, as you already have a flip kit. I am assuming that picture is of how the truck is now???? Or is this a picture of the front C30 shocks on that truck.
I would recommend shock extenders, which would allow you to utilize more of a standard shock. Make sure if you use a front shock that it has enough travel for the rear end. |
the pic is not my truck. that pic is from a c10forums member who has a flip kit and using c30 one tonne shocks. i havent bought my flip kit yet.
I figured after I wrote that.... It's late, so I will blame it on that.
anybody?
![]() Join Date: May 2011
I recommend calling Early Classic and see what they recommend and offer. There products are top notch and they have allot of experience doing exactly what you want to do. I also know that their axle saddles are only $39. For $2 more you get a solid reputation and expert advice.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
