Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-16-2012, 12:12 AM   #1
Super73
Super73's Avatar
Let the guessing game begin (going to the track this weekend)
I have been dieing to get to the track with all the changes to the truck. So, let's see who has the best guess on what the new combo will run on it's maiden voyage.
Old combo weighed 3,525 with out the tailgate and made 402rwhp with an unlocked converter (4L80E). Went 11.45@118 (with the verter locked 2nd and 3rd, 115mph unlocked).
New combo weighs 3,300 with the tail gate and now makes 546rwhp through a powerglige. If I can get it to work with out the gate, it will weigh 3,175.
Obviously I have a lot to sort out with the new 4-link, double adjustable rear shocks, different trans, automatic shifter, and trans brake. I have 2 nights to play with it, so what's your guess?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-16-2012, 12:00 PM   #2
68longhorn
68longhorn's Avatar
Re: Let the guessing game begin (going to the track this weekend)
I say 10.99 @125. Its like pass time! Good luck
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 08-16-2012, 12:28 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Just curious as to your chassis weight distribution (all four corners), and where your instant center will be located.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-16-2012, 12:50 PM   #4
Super73
Super73's Avatar
Havent corner scaled it but if memory serves it is 57/43 right now. ICG IS RIGHT ABOUT 57/5
Old 08-16-2012, 12:52 PM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
On the drag radials, or slicks?
If your runing the stickeys, and you make it hook,, 10.4's @ 130ish
On drag radials,, it's a crap shoot. 10.9 minus anything you get below a 1.6 sixty
my 2¢
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-16-2012, 01:26 PM   #6
LSPWRD67CHEVY
LSPWRD67CHEVY's Avatar
Are you going to be spraying this weekend?
1967 C-10 (project)
1964 Pontiac Lemans (Treasure lol)
2009 GMC Denali Truck (DD)
LSPWRD67CHEVY is offline   Reply With Quote
Old 08-16-2012, 02:11 PM   #7
hotrod 80
mini truck racer
hotrod 80's Avatar
10.45@130
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 08-16-2012, 03:58 PM   #8
vin63
vin63's Avatar
If you lower the instant center a couple of inches and get your 60-foots into the mid 1.5s et, low 10.40s or even 10.30s on the motor would be a good target. Sounds like it's going to be a fun weekend.
Old 08-16-2012, 04:20 PM   #9
kpeztruck
kpeztruck's Avatar
Man, all these guys are guessing the area I was going to guess. With good converter, and good hook, it should high 1.40's 60' range, and 10.40's. All bets are off if you get a wild hair and decide to spray this weekend. If the converter is fairly loose, I would run extension on the rear shocks pretty loose, and compression tight. you should hook well, if the surface is decent! Good luck... oh, we want videos!!! Paul
kpeztruck is offline   Reply With Quote
Old 08-16-2012, 07:01 PM   #10
Super73
Super73's Avatar
Right at this moment I don't plan on spraying unless it is 1/8 mile. I am only turning this combo to 7k rpm and have a 4.56/30" drag radial.
Man it would sure be nice to run what some of you are guessing (actually pretty much all your guesses would make me happy first time out with all the new stuff).
I will have some video to share!!!
Old 08-16-2012, 09:10 PM   #11
djracer
djracer's Avatar
10.70
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 08-16-2012, 10:39 PM   #12
Super73
Super73's Avatar
So on the sac raceway web page, there is a da calculator based on current temp. It is 93* out righ now and the da is 2699 feet. Racing is 6-10 pm, so the track will be warm and the da will drop a little.
Old 08-17-2012, 11:45 PM   #13
Super73
Super73's Avatar
Well, I am out of gear about 50-100 feet before the line.
Best pass so far:
1.608
6.80 @ 103.58
10.696 @ 119.89
This pass was my first trans brake launch. I did my burn out, staged, got on the 2step (3,500) lights go green and I let off the foot brake but don't move. Uhhh dummy, let go of the button. I lifted a little but stabed it and let go of the button. I let off juat after the 1,000 foot mark.
2nd best pass:
1.647
6.846 @ 103.682
10.71 @ 123.11
Old 08-18-2012, 09:09 AM   #14
djracer
djracer's Avatar
I quess I still got it. I need to go back on Pass Time!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 08-18-2012, 09:31 AM   #15
ulakovic22
I'm late to the party, was going to say 0.6 improvement. Did you run with or without the tailgate?
ulakovic22 is offline   Reply With Quote
Old 08-18-2012, 10:53 AM   #16
Super73
Super73's Avatar
Tailgate on.. Gonna try and take it off tonight. Also expecting some NGK 9's so I might get to spray to the 1/8.
Old 08-18-2012, 11:24 AM   #17
Super73
Super73's Avatar
2nd pass off the trailer. I will say the converter is definately too tight for motor. I also think a 10.5-29.5 or a 30" slick would be perfect for motor. Keep my off the line gearing and give me the growth I need so I don't run out of gearing.
http://www.youtube.com/watch?v=v3a02...ature=youtu.be
More to come tonight.
Old 08-18-2012, 12:36 PM   #18
68longhorn
68longhorn's Avatar
sweet! and nice guess DJ
Old 08-18-2012, 03:57 PM   #19
hotrod 80
mini truck racer
hotrod 80's Avatar
.2 off . Drive it out with the right tire .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-18-2012, 04:58 PM   #20
DubDubU
DubDubU's Avatar
DJ, ya shoulda went BIG!!!!
'79' shortbed
DubDubU is offline   Reply With Quote
Old 08-18-2012, 06:32 PM   #21
Super73
Super73's Avatar
No changes except the tailgate off:
transbrake with 2step at 3,500
1.576
6.713@104.65
10.566@122.66
Also notice the wheel is spinning in the tire. So there is definately more in it based on it laying over at 1200ish feet, and the 60m could be improved.
Old 08-18-2012, 10:39 PM   #22
BigDan3131
BigDan3131's Avatar
That's great to hear Super, so were the 4.56's in it with the 4L80E?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-19-2012, 09:46 AM   #23
Marv D
Marv D's Avatar
If your spinning the tire on the rim she is hooking pretty darn good!!! 10.50's on drag radials is dang respectable!!!
Just IMO here but it appears your doing it with brute force and making up for the soggy 60 just powering your way through mid track. I think I'd be cautious of hitting the tire harder with a looser convertor,,, you might shoot those 60' times right in the foot.
The top end is pretty apparent there is more there.. we all know the 'typical' gain is around 22-24mph from the 1/8th to the 1/4 for 9-11 second cars. Your only picking up 18mph,,, yeah she is running out of something up there.
I seriously think there is another 4-5mph and EASILY .2 in it.... on the motor.
CONGRATS Shaun,, That's a respectable first outting for a brand new combination!!!
Old 08-19-2012, 01:58 PM   #24
Super73
Super73's Avatar
What fun weekend!!!
So yesterday went like this:
60' - 1.576
1/8 - 6.713 @ 104.659
1/4 - 10.566 @ 122.66
Had my buddy take it for a ride, I'm 185lbs, he is 155lbs, never driven my truck. I have a window switch set to shift the truck, so, do a burn out, put it back in low gear, stage, and leave. He foot braked it rather than the trans brake, he has never used one at the track.
60' - 1.60x
Don't know the 1/8
10.6x @ ??
Then it all went to poo poo for a while. The test and tune during the day had very little traffic, and it seemed to go away for me, and my other buddy who was running a 70's Chevelle running almost exactly what I was (10.5x-10.7x on motor with same 60's).
60' - 2.306... I left of the brake, it blew the tires off, shifted, so I had to ride it out past to 60' mark, it just wouldn't be right
60' - 1.861
1/8 - 7.131 @ 103.346
1/4 - 11.021 @ 122.109
Did not lay over, forgot to plug in IAT sensor. Noticed it was pretty rich, and thought that might have been the culprit.
60' - 1.991
1/8 - 7.341 @ 103.410
1/4 - 11.221 @ 122.685
Did not lay over again, and rich again. Hmmm, something is up.
Rescaled my fueling table to lean it out as it was HOT (97* ambient / DA roughly 2700), loosened up the front 2 clicks, dropped tire pressure from 17lbs to 16lbs.
60' - 1.581
1/8 - 6.732 @ 103.762
1/4 - 10.608 @ 122.247
Touched the fuel up a pinch more, checked front shock travel, I have about 8" of upward travel and was using almost all of it so I tighten up one click. I raced an S10 on this pass. I hole shotted him but boy was it close. His is in red.
.526 - .541
60' - 1.539 - 1.674
1/8 - 6.673 @ 103.984 - 6.815 @ 108.115
1/4 - 10.54 @ 122. 293 - 10.539 @ 129.079
.015 hole shot led me to a .014 win
Changed the plugs to some NGK 9's that a buddy brought up for me. Put the bottle in, changed the tune and went to line it up. The same S10 saw me and new I went to go get the bottle and asked if I wanted to go again, bottle to bottle. I knew I was done as he told me what it runs on bottle, and I know I am out of gear, but what the heck, I don't have to win
I left on the motor, full timing off the brake, reached up and armed the system, being it is on a WOT switch, it hit right away. Just a little 57 jet (100 shot or so at 900lbs pressure).
60' - 1.521 - 1.496
1/8 - 6.301 @ 112.336 - 6.135 @ 118.44
1/4 - 10.216 @ 111.814 - 9.509 @ 142.462
I am very happy with how the truck ran, and what it ran. I wanted better than a 10.90, figured it had a 10.70, and hoped, wished it had a 10.5x in it. I think with a 29.5-30" slick, I would keep my gearing the same but the tire growth would get me through the traps without nosing over. With what it ran, I see no reason it can't go 10.4x once that is sorted out, and if I am truly lucky, maybe even a 10.3x..
Old 08-19-2012, 05:41 PM   #25
Super73
Super73's Avatar
Couple more videos.
http://www.youtube.com/watch?v=VW79v...ature=youtu.be
http://www.youtube.com/watch?v=JftXL...ature=youtu.be
