Old 08-18-2012, 11:18 PM   #1
theastronaut
theastronaut's Avatar
Steel LSx Valve Cover Flanges for Fabricated Covers?
I'm looking for a pair of steel valve cover flanges to build my own covers. I've found plenty of aluminum flanges, but I need steel flanges for this project. Anyone know who makes them?
theastronaut is offline   Reply With Quote
Old 08-30-2012, 02:43 PM   #2
theastronaut
Re: Steel LSx Valve Cover Flanges for Fabricated Covers?
Nobody? Or does anyone have access CAD files for flanges/spacers?
Old 01-17-2013, 09:49 PM   #3
theastronaut
Bump. I've started on the covers, just need a pair of flanges.
Old 01-17-2013, 11:38 PM   #4
Super73
Super73's Avatar
Not sure I have ever come accross them. You are aware that all LS heads except for 97/98 are center bolt? Bolts are going to go right through the chevy logo. I commend you for trying to make a set.
These are probably some of the better looking mass produced ones I have seem: http://www.hawkinsspeedshop.com/ls1-...olet-logo.html
These arent bad either: http://paceperformance.com/i-9375490...ed-emblem.html
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-17-2013, 11:57 PM   #5
theastronaut
I'll weld bosses (if necessary) and drill and tap the heads to make them perimeter bolt.
They'll be going in my '66 C10, first year the 327 was available in the C10 so I want to make the LS look as original as possible.
Old 01-18-2013, 04:10 PM   #6
mrhurt73
i think they would look awesome when done.
i have a question, since i am assuming your are not running the coils on top of the valve covers.
why not take the stock valve covers leave them in place. and make your old valve covers just a hair bigger on the inside diameter than the outside diameter of the stock ls valve covers.
then you could use the stock ls studs comming up out of the top of the valve cover to clip onto the underside of the sbc valve covers.
then you have no bolts going through the center, and dont have to worry about flanges or oil leaks.
just an idea and my 2 cents.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 01-19-2013, 07:40 PM   #7
72Blazing
72Blazing's Avatar
You could just buy a pair of ls1 to old style valve cover adapters like thesehttp://www.speedwaymotors.com/LS-Val...ers,41789.html
72Blazing is offline   Reply With Quote
Old 01-20-2013, 02:18 AM   #8
RaceAGMC
RaceAGMC's Avatar
Those are cool!
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 01-23-2013, 07:14 PM   #9
theastronaut
Thanks for the suggestions but I want to weld the reshaped script covers to an LS shaped flange so it looks just like an original script cover, except the ends are rounded. I want the ends rounded so it shows that it's an LS motor. The adapters wouldn't do that. The coil packs will be relocated and hidden.
Old 01-23-2013, 11:15 PM   #10
72Blazing
72Blazing's Avatar
Find someone close to you with a water jet and have some steel flanges cut to match what you are trying to do. Then you could tig weld the covers you have to those flanges. Would look pretty cool.
Old 01-24-2013, 05:09 PM   #11
1970 C10 MJW
1970 C10 MJW's Avatar
i have a pair of those valve covers in my room! I didnt realize that they made adapters! I am going to have to make my own based on those cuz I have always loved that valve cover, a buddy was guna scrap them and I begged him for them when I was like 15 lol before I had ever bought my truck or anything I knew I wanted a chevy small block LOL.
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 01-31-2013, 05:58 PM   #12
4x4toy
Find a solution yet? I want to see the finished parts. I think it will look good.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 01-31-2013, 06:44 PM   #13
theastronaut
Looks like that's what I'll end up doing. Found a guy locally that can cut them if I make patterns.
Thanks, I'm going to have flanges cut locally. Ill keep y'all posted. It's a uhh... "long term" project since I don't get a lot of time to work on it anymore.
