08-24-2012, 09:14 PM | #1 |
Gearbox help.
Recently stumbled upon a thread talking about swapping an XJ steering shaft onto a C10. This takes out the rag joint and replaces it with u-joints which is supposed to help with steering slop. Good news about this is I have a parts 87 Jeep Cherokee left over from another 87 project with my dad that I can simply pull off for free . My only question is will this work with the end fitting on a 77 gearbox? Of the 6 or 7 threads on here there seems to be a consensus that the ends changed somewhere between 77-79 and that the newer style will not work with the XJ shaft, but the end fittings can be changed (not sure on that, saw a post about it though). Does anyone know if it will work on a stock 77 gearbox? if not how easily can the gearbox ends be changed?
Thanks.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
08-25-2012, 04:59 PM | #2 |
Re: Gearbox help.
Is this the link you saw? http://67-72chevytrucks.com/vboard/s...rokee+steering
My truck is a 77 but I am using a 79 steering box(no reason in particular, this is just what I ended up with) It already has a flat spot on the splines that matches up to the Cherokee shaft. Your issues is going to be the 77 steering column unless yours has been switched out. The mating surface is a different size than a cherokee one. I am currently looking for a 78-83 steering column for mine. I guess if you wanted to weld the piece off your intermediate shaft onto the Cherokee one you wouldn't have to worry about it though. |
08-25-2012, 06:34 PM | #3 | |
Re: Gearbox help.
08-25-2012, 06:59 PM | #4 |
Re: Gearbox help.
08-25-2012, 08:51 PM | #5 |
Re: Gearbox help.
Cruise is no big deal to remove as it is just one screw to switch out the cruise control arm to the regular one. Link works now |
08-25-2012, 09:20 PM | #6 | |
Re: Gearbox help.
08-25-2012, 09:25 PM | #7 |
Re: Gearbox help.
If it is a 79 column the cruise shouldn't have anything to do with the main turn signal wiring on the column so it won't effect the fuse box
08-25-2012, 09:42 PM | #8 | |
Re: Gearbox help.
Thanks!
