Old 08-26-2012, 05:10 PM   #1
83c10wit454
83c10wit454's Avatar
Anyone runnning 22" coys up front?
Hey guys I would like to run 22x9" c5s up front on my 72. I have a drop member with tubular control arms and drop spindles. If anyone is running these wheels please let me know your set up and backspacing. Thanks
83c10wit454 is offline   Reply With Quote
Old 08-26-2012, 06:06 PM   #2
GVizzle
GVizzle's Avatar
Re: Anyone runnning 22" coys up front?
22X9 BS 5.25 I'd also call Nate and have him make you the narrower arms.
GVizzle is offline   Reply With Quote
Old 08-28-2012, 03:16 AM   #3
83c10wit454
Hey thanks. and ya my arms are already narrowed. do you have any stearing or rubbing issues? and what do have for inner fenders?
Old 08-28-2012, 09:28 AM   #4
502ms
502ms's Avatar
I'd recommend the slosh tubz for inners, otherwise you will need to make something custom.
Contact 67cheby
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 08-28-2012, 12:45 PM   #5
GVizzle
GVizzle's Avatar
I know he put narrowed arms on mine although my truck is not driving yet. Nate is making me a custom set of inner fenders because the slosh tubs would not clear the body drop.
Also I am running a 20 inch front wheel up front which will equate to a 30" tall front overall diameter with the tire.
You can check out the build thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=358687
Its near complete.
Old 08-28-2012, 12:50 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
GVizzle,... are you running 22s or 20's up front?
Keith
Convert to disc brakes.
Old 08-28-2012, 02:26 PM   #7
SCOTI
SCOTI's Avatar
Exactly... 20" front wheel w/a 30" OD tire? That's a tall freakin tire....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-28-2012, 02:29 PM   #8
GVizzle
GVizzle's Avatar
20" but rim size dont matter, its all about Overall diameter, You gonna have to run rubber bands on your 22"s
Superfly likes to run 22" all the way around. but this truck dont lay rocker. theres alot of variables. For extreme with inner fenders run 20/22 combo.
http://67-72chevytrucks.com/vboard/s...=1#post4434984
Old 08-28-2012, 02:33 PM   #9
lolife99
lolife99's Avatar
I guess I'm confused.
The OP asked if anyone was running 22" Coys up front?
Gvizzle replied 22x9,... and then replied 20's.
I understand overall tire height is what matters,... just trying to clear up the confusion.
Keith
Old 08-28-2012, 02:41 PM   #10
GVizzle
GVizzle's Avatar
I think he is trying to see if he can run a 22" up front and what backspacing to order. It doesnt matter if its 20" or 22" for backspacing. Sorry if I misunderstood the question.
Old 08-29-2012, 12:04 PM   #11
83c10wit454
Hey thanks for the info on the back spacing GVizzle. Is anyone else have 22s up front, and if so what size tires?
Old 08-29-2012, 01:32 PM   #12
SCOTI
SCOTI's Avatar
I'm more than well versed on calculating tire heights.... What size front tire do you plan to run?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-29-2012, 02:20 PM   #13
Jparks
Jparks's Avatar
I'm running 22x8.5 up front with 255/35/22 tires, the overall diameter is around 29". I don't have the narrowed arms and my backspacing is 5.5
Jparks is offline   Reply With Quote
Old 08-29-2012, 02:23 PM   #14
lolife99
lolife99's Avatar
Your truck came to mind first.
I'm not too sure there are many more with a Dropmember and 22's up front.
Keith
Old 08-29-2012, 03:45 PM   #15
ChopperCity256
ChopperCity256's Avatar
I was kinda wondering this question also.. i have a 67 with a 70 chassis and a 87 front end.. the frame is Z'd and have a drop member in the rear.. Ive bought some 22x9.5 with 5.73 bs. i'm hoping these will work..
ChopperCity256 is offline   Reply With Quote
Old 08-30-2012, 12:52 AM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
Understatement of the week.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-30-2012, 03:45 PM   #17
64shortc10
64shortc10's Avatar
Here is a dropmembered front with 22's up front not sure if it says the back spacing though.
http://www.porterbuiltfabrication.co...4-72-c10-build
Another one with 22's
http://www.porterbuiltfabrication.co...php?12-Lo-Horn
Another on 22's
http://www.porterbuiltfabrication.co...9-72-GMC-build
22's up front!
http://www.porterbuiltfabrication.co...opmember-build
This is a 63 but has 22 inch coys up front!
http://67-72chevytrucks.com/vboard/s...d.php?t=324303
Hope this helps get you some info.
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 08-30-2012, 11:55 PM   #18
ChopperCity256
i Z'd my frame and have a 87 front end on it with3'' drop spindles. i was wonder if i could get 22x9.5 with a 5.73 bs to tuck?
Old 08-31-2012, 08:27 AM   #19
Jparks
Jparks's Avatar
I don't think that's going to work. I think you're gonna be about 3/4 of an inch from being able to tuck. I've got 22x8.5 with a 5.5bs like I posted earlier and I'm about as close as I'd want to be from the fender lip. You'd need around a 6.5bs with a 9.5 rim.
Old 08-31-2012, 08:30 AM   #20
SCOTI
SCOTI's Avatar
I don't think that's going to work. I think you're gonna be about 3/4 of an inch from being able to tuck. I've got 22x8.5 with a 5.5bs like I posted earlier and I'm about as close as I'd want to be from the fender lip. You'd need around a 6.5bs with a 9.5 rim.Posted via Mobile Device
It ultimately depends on 'actual' track width. I'd agree that the 9.5" wheel is going to need 6+"bs on anything that's close to the stock width.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-31-2012, 08:32 AM   #21
ChopperCity256
Yea? Damn.. do you have a stock front end or do you have a drop member?
Old 08-31-2012, 08:53 AM   #22
Jparks
Jparks's Avatar
I have a dropmember but don't have the narrowed arms.
Old 08-31-2012, 11:19 AM   #23
SCOTI
SCOTI's Avatar
ChopperCity256, keep in mind a DM w/o narrowed arms is still 2+ inches narrower than stock.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-02-2012, 05:16 PM   #24
83c10wit454
So if i have a dm with the narrowed arms and a 22x9 i should have about a 6" back space, correct?
Old 09-03-2012, 12:31 PM   #25
SCOTI
SCOTI's Avatar
That would be pretty close. N2Billet runs a DM w/narrowed PB arms on his 67 patina'd truck Hazel & 22x8.5's w/5.25" bs. Keeping everything else equal from the outer edge of the tire (for fenderwell clearance), you add the difference to the BS number (9.0 - 8.5 = .5; .5 + 5.25" = 5.75" minimum).
Caveat Emptor.... That much BS can cause other issues (turning radius, inner rubbing on some a-arms, etc...) so investigate thoroughly w/a tape measure on your exact parts.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
