Old 09-05-2012, 11:29 AM   #1
weider1717
zero rates all the way around?
Since the zero rate is another leaf really and keeps the ride the same is there any reason I couldn't put them all the way around to give me a 1" lift? I am running 32x11.50s on my stock rallys on my 87 and when backing up and in a bind sometimes you can feel it SLIGHTLY rub I think that 1" would correct it and was just curious.
weider1717 is offline   Reply With Quote
Old 09-05-2012, 12:23 PM   #2
AJII
AJII's Avatar
Re: zero rates all the way around?
Nope, no reason you can't.
I run them on the front to put the wheels in the center of the wheelwells. The added lift was just a bonus.
1985 K10 Under Severe Reconstructive Surgery
5.3/New Paint/New Interior/Yadda Yadda Yadda
AJII is offline   Reply With Quote
Old 09-05-2012, 06:37 PM   #3
76stepsidechevy
I just put a set on the front of mine. Although I just made mine out of some 1x3 bar stock we had laying around at work. I've got a 6 in BDS lift on the truck and it sat nose down by about 2 inches. They're safe since they're bolted to the spring pack like an extra leaf.
76stepsidechevy is offline   Reply With Quote
Old 09-06-2012, 05:11 PM   #4
weider1717
thats what I thought! thanks
Old 09-07-2012, 07:33 AM   #5
Boostaddict
I'm a truck suspension newb but have a directly related question about this. I bought a set of used wheels with 285/75/16 tires for my 3/4 ton 4x4 and they rubbed the front fender just a little bit approaching wheel lock in each direction. Would this be a valid option then to gain just a hair (an inch) of additional clearance? What about the issues like steering length/geometry that people mention with the real lift "kits" would anything else need to be done or just install and go? I have a bit of fab experience so making steel blocks would be pretty easy or I see there are some inexpensive kits out there too:
http://offroaddesign.com/catalog/Zero%20Rates.htm
^ says the optional 1" offset in addtion to the 1" lift might cause steering issues. Sounds like I could just replicate the above kit on each corner (or buy 2 of these)?
1980 GMC Sierra K25, Original Family Farm Truck
Boostaddict is offline   Reply With Quote
Old 09-07-2012, 06:20 PM   #6
76stepsidechevy
If the truck isn't already lifted then you probably wont have any steering issues going up an inch. I already had a 6 in lift with a raised steering arm and it made the drag link angle a bit too steep. I ended up adding a dropped pitman arm to get it closer to level. I didn't move the axle forward at all though.
