Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 09-05-2012, 10:19 PM   #1
69 gmc
69 gmc's Avatar
Help me on an Order from Top Banana?
This first photo is the drivers side.
I need to repair the floor section that you can see has a hole in it as well as the metal piece that goes in behind the outer rocker panel all the way to the back.
Name:  cab floor.jpg
I'm not 100% certain that I've found the right part, I assume the part displayed is slightly different from what I will receive. (maybe they only had a picture of the same part but for a different year) The part is called a "Driver Side Cab Floor Exterior" and states that it is for the 67-72 chevy pickups. I just want to know if what I found is correct. It costs $57 on Top Banana.
Name:  cab floor part.jpg
Any input is appreciated.
Calder
69 gmc is offline   Reply With Quote
Old 09-05-2012, 10:21 PM   #2
jocko
jocko's Avatar
Re: Help me on an Order from Top Banana?
yep, tough call - I'd ask them if it's exactly what's pictured - if yes, I'd look elsewhere - if no, then I'd ask them about their return policy, and if it's acceptable, give them a shot.
Lots of places put generic photos of the general area - I find it annoying, but it's somewhat common.
Old 09-05-2012, 10:25 PM   #3
69 gmc
69 gmc's Avatar
I mean it looks similar in a few ways but not totally.
Calder
Old 09-05-2012, 10:38 PM   #4
69 gmc
69 gmc's Avatar
Anyone have any other info?
Calder
Old 09-05-2012, 10:43 PM   #5
c1069
c1069's Avatar
That's the part also you need rocker too. I did the same with my floor
Pancho
69 c/10 step side 454/400 with 3.07
c1069 is offline   Reply With Quote
Old 09-05-2012, 11:03 PM   #6
c1069
c1069's Avatar
Also called Floor outer complete section, left side
http://www.classicparts.com/1967-72-...info/45%2D945/
Pancho
Old 09-05-2012, 11:29 PM   #7
69 gmc
69 gmc's Avatar
Thanks you guys! I already have the other parts in my cart and I know that I have all of those correct. I am going to put in my order, thanks for the fast feedback
Calder
Old 09-06-2012, 07:51 AM   #8
I hope that's for some other application,because it sure isn't made the same as OEM. isn't there a longer part you can get that goes to the back of the cab? I haven't had to buy these parts,but I believe they are called outer floor extensions.
Old 09-06-2012, 09:10 AM   #9
69 gmc
69 gmc's Avatar
Well the order has already been placed so I guess thats the only way to know for sure, I will leave an update when the parts arrive.
Calder
Old 09-06-2012, 10:40 AM   #10
c1069
c1069's Avatar
That is the part, i'm 100% sure if you ordered the part listed above.
I had to buy the same part from board vendor. That will work goes along all the floor section.
Pancho
Old 09-06-2012, 11:58 AM   #11
69 gmc
69 gmc's Avatar
Thank you for the reassurance, it's not a cheap part when compared to the other parts. (rockers, cab corners...etc.)
Calder
Old 09-06-2012, 12:11 PM   #12
Johnnyfever
Bought mine from AutoMetalDirect.com and the parts were exactly like your original. Bonus for me is that they are local.
Johnnyfever is offline   Reply With Quote
Old 09-06-2012, 01:33 PM   #13
Tim Christian
Tim Christian's Avatar
The picture showing is 60-66 not 67-72
Tim Christian is offline   Reply With Quote
Old 09-06-2012, 10:33 PM   #14
69 gmc
69 gmc's Avatar
Thats what I was thinking!
Calder
Old 09-06-2012, 10:46 PM   #15
BMERDOC
BMERDOC's Avatar
Dang! As I was scrolling down I was hoping no one else would know. Tim beat me to it and he should know. I found someone selling these same pieces on CL yesterday. I shopped it for comparison so I recognized it right off. Yup, the pic is 60-66.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-08-2012, 08:20 PM   #16
scapegoat67
scapegoat67's Avatar
Ditto on the above . You should put the front and rear cab mounts in also . Hell your right there working anyway . It's going to need it.
scapegoat67 is offline   Reply With Quote
