09-11-2012, 02:00 AM | #1 |
Steering column rebuild
I have searched this site, my factory manual, and the web and
Can't find a diagram or part numbers to rebuild my 1965 steering Column! I want to keep it stock as much as possible! Please help y'all! Posted via Mobile Device
1965 Chevy C-20 slammed 292 L6 TH400 1967 Chevy C-20 on 91 suburban frame project(wife's) 1972 Chevy K-20 Mild 350/th350/np2o5 dd 1952 Ford Customline 2door kustom project 1967 Cadillac Superior Hearse (wife's) 1998 GMC Saffari (wife's dd) |
09-14-2012, 02:46 PM | #2 |
Re: Steering column rebuild
No help? I'm not the only one!
09-14-2012, 10:40 PM | #3 |
ive got problems with my 66 too. cant find many parts or rebuilt columns... taking my 3 on the tree out tomorrow and going with floor shifter.
09-14-2012, 11:15 PM | #4 |
does the 3 on the tree bother you guys?
I've got 99 problems but a shift ain't one. |
09-14-2012, 11:36 PM | #5 | |
Samba when I turn! My 65 was a power glide stock but th po installed a Th400 Posted via Mobile Device
1965 Chevy C-20 slammed 292 L6 TH400 1967 Chevy C-20 on 91 suburban frame project(wife's) 1972 Chevy K-20 Mild 350/th350/np2o5 dd 1952 Ford Customline 2door kustom project 1967 Cadillac Superior Hearse (wife's) 1998 GMC Saffari (wife's dd) Last edited by oakstcustomz; 09-14-2012 at 11:38 PM. Reason: Update |
11-13-2012, 03:23 PM | #6 |
So I found a 4 speed truck and got the pedals
and steering column before it was crushed..... I bit the bullet and yarded my steering column out and there is not much to it! Rag joint Then a bolt through clamp bracket, spring, the lower bearing wich is easy to replace and was the cause of my problem in the first place Posted via Mobile Device
