Old 09-11-2012, 12:45 PM   #1
AngryPirate
AngryPirate's Avatar
Pictures of rear shock mounts on trailing arms
I think the PO installed the mounts backwards, like those triangle shaped metal pieces that the bottom of the shock connect to are more towards the rear of the truck (spun around) than they are supposed to be.
Thanks for any pics!
- AP
AngryPirate is offline   Reply With Quote
Old 09-11-2012, 01:29 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Pictures of rear shock mounts on trailing arms
Sounds as if he switched them from side to side, just reverse them, they should be facing towards he front.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 09-11-2012, 02:57 PM   #3
McCoyAZ
McCoyAZ's Avatar
On my 64
McCoyAZ is offline   Reply With Quote
Old 09-11-2012, 03:01 PM   #4
AngryPirate
okay, my mounted are a little different looking, but those pics show that the shocks should be in the front of the axle. Mine are behind.
Can anyone see any reason why the PO would do this? Also note that he put a flatbed on it, but the frame is unchanged so it shouldn't matter (I wouldnt think).
It does looks like I need to spin those mounts (or swap and spin) around and then route the shock in front of the axle.
Thanks for the posts and pics! Super helpful.
Old 09-11-2012, 04:27 PM   #5
forestb
forestb's Avatar
What year is your truck? On my 62 the shocks are behind the axle. my guess is that 63 and up are in front of the axle and 62 and under are behind.
forestb is offline   Reply With Quote
Old 09-11-2012, 04:34 PM   #6
AngryPirate
Mine is a 61 LWB
Old 09-12-2012, 11:21 PM   #7
oem4me
oem4me's Avatar
Bingo! search thru the build threads for bare frame resto pics.
Old 09-13-2012, 12:01 AM   #8
losthope
losthope's Avatar
Your correct on the earlier x-frames having the shocks mounted behind the axle..the later ladder bar frames are mounted in front of the axle....
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
rear shocks, trailing arms
