Old 09-15-2012, 04:35 PM   #1
cmyc5575
To coil or to spindle, that is the question?
Ok I have the money for my 2/4 drop and was wondering if I should go with 2 in coils or 2 in spindles for the front and why one makes since more than the other?
cmyc5575 is offline   Reply With Quote
Old 09-15-2012, 09:16 PM   #2
cmyc5575
Re: To coil or to spindle, that is the question?
anyone?
Old 09-15-2012, 09:40 PM   #3
legendman
legendman's Avatar
You could just cut a coil out an save some dough towards spindles down the road
I plan on doing both coils and spindles
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 09-15-2012, 09:48 PM   #4
71swb4x4
71swb4x4's Avatar
IMO spindles is always a good one to do first. It doesn't mess with any of the suspension geometry. You are simply moving the placement of the wheel, everything stays as it should with the geometry of the suspension.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-15-2012, 09:58 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
I agree with 71swb, Spindles are best if you have the choice. Then later if you want to go lower (most do) all you have to do is cut a coil or two off the stock springs.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 09-15-2012, 10:47 PM   #6
cmyc5575
I am mainly concerned about ride quality. Dont want one to be more rough than the other so Id rather do it right the first way. LOL yes I plan on going lower in the future.
Old 09-15-2012, 11:57 PM   #7
misslemanid
Go with spindles. Best ride quality and keeps the stock geometry. If you plan on going lower in the future, go with 2.5" spindles. The extra half inch will make a big difference in ride quality when buying drop springs in the future.
misslemanid is offline   Reply With Quote
Old 09-16-2012, 12:16 AM   #8
frog210
"Little voice in head"
Bag it
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 09-16-2012, 12:44 AM   #9
Mike Bradbury
Mike Bradbury's Avatar
You'll be much happier with dropped spindles.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 09-16-2012, 12:54 AM   #10
cmyc5575
Bag it
lol .. I wish! But I will deffinately buy the spindles over the sprigs that makes seanse. What does the big difference form the .05 inch difference I dont understand that one?
Old 09-16-2012, 01:13 PM   #11
INSIDIOUS '86
INSIDIOUS '86's Avatar
Before we jump in on spindles what wheels are you running? Don't buy drop springs. Those suckers bounce and the springs attenuate horribly and not even good shocks help. If you plan on going very low up front like a 6 inch drop find some used 3/4 ton springs at a wrecking yard and cut them otherwise cut half ton springs are a good idea as well for 5 inch drops.
Btw 2-4 drops don't look good IMO since the front always seams to look taller than the rear. I would suggest a 3in drop up front
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-16-2012, 07:53 PM   #12
3r!c84
Badass
3r!c84's Avatar
reminder, going with aether springs or spindles a alignment will be needed after the instal.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-16-2012, 10:59 PM   #13
misslemanid
A half inch lower doesn't seem that much on paper but does make a difference on how much spring you hafta cut in the end to get as low as you want. The less spring you hafta cut the better the ride. I'm sure there is some type of scientific explanation but the more spring you cut, the more you mess up the stock geometry and you also get more of a bounce. The above people are right. Drop springs tend to be a bit more stiff and bouncy. Also, if you like wheel size options, the 2.5 drop spindles let you still run 15" wheels. 3" drop spindles require some grinding to clear the wheels unless you run a bigger wheel diameter.
Old 09-16-2012, 11:24 PM   #14
king-918
king-918's Avatar
You can start with bagging the front for a relative cheap price, then tax time do your rear
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 09-18-2012, 06:13 PM   #15
cmyc5575
Sorry guys been away from the cpu for a couple days but the tires and wheels are p255 70r/15's I like them but would like to run a lil wider tire eventually.
Name:  New Image.jpg
Old 09-18-2012, 11:30 PM   #16
'79squared
'79squared's Avatar
From my experience, neither my 79 nor my friends 86 needed an alignment after 2.5 drop spindles on mine or his 3" spindles. Only the springs will cause an alignment issue and you will have to shim the upper a arm out where it connects to the frame.
1979 SWB 350/350
'79squared is offline   Reply With Quote
Old 09-19-2012, 02:01 AM   #17
INSIDIOUS '86
I'm finding that drop springs are actually soft and mushy which causes the bounce. Kinda like an old Cadillac. Great if rolling low and slow is your style lol
Old 09-19-2012, 05:33 PM   #18
cmyc5575
lol I think this is my way! I just enjoy looking good when i do it.
