Old 09-17-2012, 03:07 PM   #1
jrsavoie
What is this 1994 NV4500 worth?
‎1994 GM NV4500 5 speed manual transmission from a K3500 6.5 diesel 4x4 Casting number C - 16812
Needs input shaft, input shaft bearing and 3rd gear synchro At the least.
I drove this transmission up til About September 2012. I pulled the NV4500 transmission because of the 3rd gear synchro not working after I had found a rebuilt unit.
I did not find out about the input shaft and bearing till after I pulled the transmission. The pilot bearing had gone out and chewed up the tip of the input shaft.
I swapped For a rebuilt.
It has the round shifter top and the 6.34 1st gear ratio.
The trans is from a diesel and has the balancer
I also have a rectangular shifter, spacer and shift lever/handle with knob. It is missing one of the 4 steel bushings that goes around the bolts through the spacer. This part will work on Dodge NV4500's also. What is the shifter worth?
Where would a good place to advertise these items be?
98 GMC Suburban 2500 6.5 4x4 235,000 mi, FS2500, 96 GMC 6.5 Suburban 1500 4x4 280,000 mi; Amsoil 95 Tahoe 2 door 4x4 6.5 280,000 mi; 91 international 4700 low pro, spicer 6 speed, DTA 360 with 18' van box 500,000 miles plus.1994 chev K3500 crew cab SRW 5 speed 4x4 245,000
jrsavoie is offline   Reply With Quote
Old 09-19-2012, 09:30 PM   #2
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: What is this 1994 NV4500 worth?
I will gladly take them off your hands if you don't want them haha Not really sure what there worth. Just figured I would offer though.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-20-2012, 01:05 AM   #3
jrsavoie
Make that offer anywhere a neighborhood worth my while and you can be the happy owner. I think this trans would be an easy rebuild.
The input shaft was taken out by the pilot bearing and I'm sure that took out the input shaft bearing. That and the 3rd gear synchro shouldn't be to terrible.
I advertised the NV4500 for $400
