Old 09-20-2012, 07:45 PM   #1
SunSoaked
SunSoaked's Avatar
BulletProof 6 speed auto w/NP205
Sounds tempting does it? Just pondering my options and was looking into a turbo 400 with the gear vendors OD. The GV replaces the output on the 205. The controller shifts it automatically between shifts 1, 1 over, 2, 2 over, 3, 3 over. You can disengage it with a foot switch (like the old floor mounted dimmers).
I like the idea and it would be a stout setup.
Aint cheap ($3K), but has alot of advantages.
Disavantage; No engagement in 2wd, but come on, who runs in 4wd at highways speeds?
Hmmm.....
SunSoaked is offline   Reply With Quote
Old 09-20-2012, 07:59 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: BulletProof 6 speed auto w/NP205
Meh, if you want a cheaper darn near bullet proof 6 speed auto go find yourself a 6L90 from a late model GM truck and not monkey with that aftermarket stuff. The 6L90’s aren’t quite an Allison but they are holding up a lot better than any 4L80E ever could. Ask any GM dealer how many warranty repairs they have done on 4L80E's vs. 6L90’s. 6L90 failures of any sort are very few and far between. If I had to have an auto, a 6L90 would be what I would go after but until both of my legs fall off I'll stick with manual transmissions.
DirtyLarry is offline   Reply With Quote
Old 09-21-2012, 12:34 AM   #3
Mr. 250r
Mr. 250r's Avatar
You also have to think the 4l80s came out how many years before the 6L series so there obviously going to have more problems and with newer technology gm continues making better products and as far as autos and manuals i would like a fast shifting 4x4 6spd like a 4wd t56 or a lenco 6spd clutchless =-p
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 09-21-2012, 05:51 AM   #4
Redcap
Personally, I'd never put an automatic in a truck.
Redcap is offline   Reply With Quote
Old 09-27-2012, 03:31 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea I was thinking along the same lines. Be a heck of a lot cheaper that's for sure. I have had autos and sticks. I will sticks better there funner and don't break as much haha
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-01-2012, 05:03 AM   #6
andrewmp6
Yeah i would go with a beefed up 4l80 less moving parts less stuff to go wrong or break.
andrewmp6 is offline   Reply With Quote
Old 10-01-2012, 10:41 AM   #7
SunSoaked
SunSoaked's Avatar
less moving parts..like no 5th gear. Thats the whole point.
Old 10-01-2012, 06:36 PM   #8
chevak20
I am about to put the same in my suburban, but it is the older gear vendors.
I hope it will work out fine. I am going to have a manual switch to activate it, and a switch feeding it only in 2wd.
My transmission kit came out of an -86 crew cab diesel.
chevak20 is offline   Reply With Quote
Old 10-02-2012, 02:28 AM   #9
andrewmp6
I know tci makes a 6 speed trans its based on the 4l80 but I'm not sure if it will work on a 4x4 or not.What kinda engine will you be using and how power does it have or will?
Old 10-02-2012, 07:33 AM   #10
chevak20
I will use the 6.2 diesel that came with it.
Here is a picture of it.
My Gear Vendors are a J type by the way.
Old 10-02-2012, 11:01 AM   #11
SunSoaked
SunSoaked's Avatar
