Old 10-01-2012, 04:51 PM   #1
CRGRS 66
CRGRS 66's Avatar
Looking for Rear Suspension Advice
I want to lower my rear end 4" from stock height, seems to be currently sitting about 2" lower than stock height. Someone suggested bagging it, but I don't know if I want to go there. I have no experience with bagging, and I am not a welder fabricator, prefer to bolt on my mods. I have no interest in laying it out, or C-Notching etc. It would however be nice to have the ride height adjustable for when I am towing, or have a load of wood.
Open to suggestions, sorry, could not imagine what to search for to find the help I am looking for.
If you take the time, I thank you in advance for your input.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 10-01-2012, 04:57 PM   #2
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Re: Looking for Rear Suspension Advice
4" Springs or 2" blocks with what you have. Would be the cheapest.
Could do a schrader valve rear bag setup. (Valves you would air up with air compressor... no onboard air supply.)
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 10-01-2012, 05:03 PM   #3
65Gregg
65Gregg's Avatar
Too bad you're north of the border, I have some leftover CPP bits & pieces...blocks would be a good start.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 10-01-2012, 05:11 PM   #4
CRGRS 66
CRGRS 66's Avatar
I have been considering 4" lowering springs and matching shocks. As long as I am dismantling it, I plan to upgrade with new parts, so, not necessarily looking for the cheapest method.
I like the sound of the bags that you pressurize with a tire type valve. Don't know where to start looking at that type of product, or have any idea how that system would work. Sounds kind of like the air shocks guys use to put in their dads car to jack up the rear end...
Craigerrr
Old 10-01-2012, 05:13 PM   #5
CRGRS 66
CRGRS 66's Avatar
Very kind of you. Not sure what you have, and if it would be of any use to me, but I do have an address in buffalo... my cousins in-laws.
Craigerrr
Old 10-01-2012, 05:15 PM   #6
CRGRS 66
CRGRS 66's Avatar
thanks for the input
Craigerrr
Old 10-01-2012, 05:26 PM   #7
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Check the suspension marketplace... AVS_JASON was running a special for a schrader valve kit.
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 10-01-2012, 05:26 PM   #8
65Gregg
65Gregg's Avatar
Never mind, I just remembered the parts I have are for a 5" drop not a 4"...
65Gregg
Blue long bed
White TBSS
61 Impala
Old 10-01-2012, 06:08 PM   #9
Pro Performance
Pro Performance's Avatar
You could go with the Porterbuilt rear kit, and just add some misc. fittings and tire valves to make it work. It is all bolt-on and will give you the adjustability.
http://www.azproperformance.com/Port...-Rear-Kit.html
Pro Performance is offline   Reply With Quote
Old 10-02-2012, 10:50 AM   #10
Portmod7
Portmod7's Avatar
I don't think you can go wrong with simply installing 4" drop springs and be done with it. If you load it up once in a while, and notice you need a little more spring, put some helper air springs on it and air them up when you want to haul.
I don't understand why you would run bags just to get a 4" drop. They are great if you want to ride really low so you can raise it up in some situations, or even set the thing on the ground when you park. And I'm not saying they can't be made to ride well or perform well, it just seems like way too much trouble for a simple 4" drop.
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 10-02-2012, 12:54 PM   #11
CRGRS 66
CRGRS 66's Avatar
Thank you!
A kind offer none the lees, thanks!
Something to consider for sure, this I take it would be in place of springs?
Appreciate the input, helper springs an option, not sure where I would look for these.
All of the input is much appreciated!
Craigerrr
Old 10-02-2012, 01:27 PM   #12
Pro Performance
Yes, it would take place of the springs.
Old 10-02-2012, 01:33 PM   #13
CRGRS 66
CRGRS 66's Avatar
I find this an interesting option.... shocks?, trac bar, what should I do there if I go this route, will I need any other changes or components? Should we maybe communicate outside of the forum via email?
Craigerrr
Old 10-02-2012, 01:43 PM   #14
Pro Performance
Sure, that is no problem and we can go over the details. You can give me a call @ 480-420-8175 or email me at: travis@azproperformance.com
Travis
Old 10-05-2012, 10:17 AM   #15
6772owner
Gearhead
6772owner's Avatar
I used the ECE rear kit in my 72' C10 and loved it, lowered the rear some, great load capacity, rode nice, relocated the shocks, included an adjustable track bar and I never had a single problem with it. Their kit uses the large Firestone sleeve bags (think small semi) and they are awesome, just my .02.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 10-05-2012, 10:22 AM   #16
CRGRS 66
CRGRS 66's Avatar
Thank you, I have been giving it a lot of thought, I am leaning toward the porterbuilt bags and adjustable track bar. Just set up a shraeder valve somewhere hand for when I want/need to adjust ride height.
Craigerrr
Old 10-05-2012, 10:40 AM   #17
6772owner
Gearhead
6772owner's Avatar
Cant go wrong with anything Porterbuilt, I bought mine before I knew there was other options (and it was like 8 years ago). I used individual shraeders as the license plate bolts for years before I went to on board air, it works just fine, I carried a small 12v (cigarette lighter type) air compressor in the truck just in case... it came in handy more than a few times.
Old 10-05-2012, 11:18 AM   #18
jimmydean
jimmydean's Avatar
This is just like the rear setup I used on my '69 because I didn't want to do the notch yet. It was awesome to be able to adjust the height because I towed with my '69 as well.
And Nate overbuilds everything, so you know it's built to last.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-05-2012, 11:43 AM   #19
robnolimit
robnolimit's Avatar
Try a combo of 2" blocks, and a 2" spring. This set up fools the back of the truck into thinking that it only has a 2" drop. So, stock length shocks, and the OE panhard rod are still good. As for upgrades from there, 1) rear sway bar, 2) long adjustable panhard rod and mount kit, 3) shock re-locators and shocks. No notch needed for a 4" drop.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 10-05-2012, 12:32 PM   #20
CRGRS 66
CRGRS 66's Avatar
thanks jd, yes, I like the flexibility for towing and loads
thanks rob, I am planning on a sway bar as well, looking at the porterbuilt bag kit, and long panhard bar, and the CPP forward facing sway bar. I am also close to pulling the trigger on a CPP front drop/disc brake kit, and 2" lowering springs and shocks. Do you have like products that I can consider, maybe PM me.
Craigerrr
