1960 GMC Rear Swaybar Mounts
As I was working on the rear brakes of my GMC, I noticed it has a rear swaybar, but the ends are not botled to the axle. Are the end links hard to find? What do they look like? Thanks!
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
Senior Enthusiast
Re: 1960 GMC Rear Swaybar Mounts
To the best of my knowledge GMC never added a rear sway bar in 1960. Mine didn't even have one in the front, so I would assume it's an incomplete aftermarket setup.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
They didn't have a sway bar.
Do they look like pieces of leaf springs? You might be looking at the optional helper springs. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
I've seen the helper springs, it is a swaybar. I'll take some pics tomorrow...I already have the back wheels off so I can fix the brakes.
I have a '60 with a sway bar. Looking forward the left side mounts to the fran and the right goes to the top of the axle.
http://s1299.photobucket.com/user/jb...23904108567829 |
Thats a track bar, a sway bar will have four mounting points. two to the frame two to the axle.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Senior Enthusiast
If you truly have a rear sway bar with missing components, you might want to check with either (or both) Hellwig or Addco. They have both been around for decades providing universal and aftermarket bars to the auto industry. If you could find an interested tech they might be able to fix you up with what's missing.
http://www.addco.net/aftermarket/ http://www.hellwigproducts.com/produ...suv-sway-bars/
Thank You, I didn't that. learned something today.
