10-21-2012, 01:50 PM | #1 |
1969 dual MC in a '65 c10 - brake rod length questions
Howdy folks.
I have a 1965 c10, but it has a 1969 dual pot, power brake master cylinder on it. Below is a photo of my brake rod that connects from the brake pedal to the MC assembly. This brake pedal push rod is from a 1965 Chevrolet C10 pickup(at least, that is what it came off of) is 8 5/8 inches long from the round end to the threaded end. 7/16 - 20 thread. more pics, here My question is this... is there a '67-'72 brake pedal rod that is longer, but will fit in the same place? A lot of stuff on my truck is from different years, etc.. Thanks a bunch for any information. -W Last edited by Woogeroo; 10-21-2012 at 01:57 PM. |
10-21-2012, 10:32 PM | #2 |
Re: 1969 dual MC in a '65 c10 - brake rod length questions
I dont think we have one of those around. I am going to drive my 70 tomorrow. Ill have a look at it but i am not sure I can measure that on the truck. Mine is not original either. I believe it came from a 71.
George |
10-21-2012, 11:02 PM | #3 |
I think what you'll have to do is get a threaded coupler and a piece of allthread and make it longer. You run into a similar problem when you put a 73-87 C20 booster on a 67-72.
http://www.mcmaster.com/#right-hand-...g-nuts/=jtpalm
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
10-22-2012, 12:42 PM | #4 |
airdale94,
howdy. Yep, I was pondering the coupler method and cutting it to fit. Thanks for the tip/reply. I had a one piece, longer rod I made in machine shop class years ago outta some nice steel... but I had a panic brake stop the past Saturday and dog gone if it didn't bend the rod! Ooops. Good thing I'm a pack rat and kept the original rod in my parts stash! -W |
10-22-2012, 04:04 PM | #5 |
It has one rod from the pedal to a pivot. The other rod on the pivot goes to the brake booster. I have no idea about the length.
George |
10-23-2012, 12:29 PM | #6 |
Thanks Wrenchbender Ret..
I was looking on a few vendors sites and noticed that pivot, was wondering about it. -W |
