Old 10-31-2012, 01:07 PM   #1
Tonio327
1986 and up tbi 700r4 dent cable installation
I have a 86 the first year of the tbi I had me trans 700r4 installed by Aamco. They had problems with getting the dent cable adjusted on the TBI they was asking me to change to a carb I refused I don't think it's shifting right wonder if anyone no and thing that's diffrent about putting this cable on a tbi over a carb the only thing I no now that should b simple is the throttle needs to be all the way open and the cable needs to be tight
Tonio327 is offline   Reply With Quote
Old 10-31-2012, 02:32 PM   #2
legendman
legendman's Avatar
Re: 1986 and up tbi 700r4 dent cable installation
Might be time to switch shops, should be no reason anyone can't properly adjust detent cable on a 700r4 regardless if its a carb or tbi
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 10-31-2012, 03:23 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
First tell us the shift points. Does the cable bind anyway? Did they install a new cable with the 700R4? Is cable end adjustable? Detent cable is for a 350TH, TV cable for 700R4.
Set it this way: http://www.73-87.com/7387garage/drivetrain/tvcable.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-31-2012, 03:50 PM   #4
rfmaster
rfmaster's Avatar
AAMCO is the last place I would trust with a transmission job (or anything for that matter) as over the years my family members had nothing but bad rebuild jobs or incorrectly installed transmission. Learned from their mistakes
If you have original throttle bracket it should be attached to the intake and intake manifold to head bolts. It is critical to get 700R4 TV cable adjusted correctly. The most common problem is incorrect replacement cable. TV Cable adjustment procedure can be found here:
http://news.compperformance.com/Inst...ble_adjust.pdf
I had reasonable results using a universal replacement cable from TECKPAK - which can be found locally or on Ebay.
Since your truck was originally was equipped with TBI Aamco has no business telling you to switch to a carb. It is wrong for many reasons. A word of advise - leave that shop as quickly as possible.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 10-31-2012, 04:00 PM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
86 should not have TBI.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 10-31-2012, 09:42 PM   #6
gchemist
gchemist's Avatar
It can if the original engine was a V6.
Old 11-01-2012, 07:35 AM   #7
RandyP
RandyP's Avatar
You sure? It always stuck in my head 87 was the first year for the trucks to have TBI no matter the engine size. Not doubting you on it just don't recall that.
Old 11-01-2012, 07:57 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
I went threw this with Keith,a quote from him to me
To answer your earlier question: no TBIs on fullsize trucks in '85. We've had this discussion before and I can answer with confidence, because I 've had conversation with the GM Powertrain guys who did the calibrations for these TBI engines. They have said no TBIs until 1987 model year.
besides that I'd change shops TBI is much better to run then carb
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-01-2012, 08:48 AM   #9
RandyP
RandyP's Avatar
Is why I'm fairly confident in my saying there was no TBI offered in full size trucks until 87. I know some GM cars and perhaps the S series had TBI/FI before 87, but not the full size trucks/SUV's.
Old 11-01-2012, 09:55 AM   #10
rs72z
rs72z's Avatar
I thought the v-6's were still carbed in 87.
I agree no tbi on trucks before 87.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 11-01-2012, 07:28 PM   #11
gchemist
gchemist's Avatar
4300 applications:
1985–2005 Chevrolet Astro/GMC Safari
1991–1993 GMC Syclone/GMC Typhoon (See LB4 below)
1988–1995 Chevrolet Blazer/GMC Jimmy
2001–2002 Chevrolet Express/GMC Savana
1988–2003 Chevrolet Silverado/Chevrolet S-10/GMC S-15
1994–2001 Oldsmobile Bravada
1985–2001 Chevrolet C/K
Old 11-01-2012, 07:32 PM   #12
gchemist
gchemist's Avatar
Here is a carbed 4.3 86 truck.
http://www.purplewave.com/cgi-bin/mn...090811/6650/13
Old 11-01-2012, 07:41 PM   #13
gchemist
gchemist's Avatar
GM history on V6.
Chevrolet kicked off a 75th anniversary celebration in 1986. By year’s end, the company would make 1,174,217 trucks. New was a high-tech instrument cluster. The Vortec V6 had electronic fuel-injection and swirl-port heads for a nine percent power boost. It was Chevy’s most powerful base truck engine ever
http://www.pickuptrucks.com/html/sto...art2page1.html
Old 11-01-2012, 11:06 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
cars were first
mid size trucks, a friend had a mid jimmy with that 4.3...remember it being carbed tho
John
Old 11-02-2012, 08:50 AM   #15
RandyP
RandyP's Avatar
TBI did start coming out in full size trucks in 1986. The trucks were "1987" models though and not 86 year trucks. Just like the new body style 88 model trucks came out in 1987... They were still 1988 model trucks despite it being early 1987 still.
1987 year model trucks was when TBI was introduced to the full sizes.
