Old 11-05-2012, 05:37 PM   #1
Racer2172
Wheel size 17'' to 16"
I have a 2005 Chevy silverado crew cab 2wd that has the stock 17 in steel wheels. It has disc brake front and drum rears. Can i put 16 in rims stock without issues. It will give me a better selection and cheaper cost of new tires if i can do this. Any info on this?
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 11-05-2012, 06:25 PM   #2
68Stepbed
68Stepbed's Avatar
Re: Wheel size 17'' to 16"
No. In 05, they started installing 13" disc brakes. 17" wheels are the minimum size wheel that will fit on 05-up trucks.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-08-2012, 03:51 PM   #3
km16
I put 16 inch wheels on my pickup but I had to grind down the front calipers for clearance. Probably not the right way but worked. And 16 inch tires are cheaper than 17s.
km16 is offline   Reply With Quote
Old 11-08-2012, 05:54 PM   #4
Racer2172
Do you have a pic of where you ground the calipers also is there any issues with speedo calibration with the 16" tires?
Old 11-08-2012, 11:00 PM   #5
clinebarger
DO NOT modify brake components.....Common sense guys.
clinebarger is offline   Reply With Quote
Old 11-08-2012, 11:28 PM   #6
Boog
laying low
Boog's Avatar
Right.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-11-2012, 08:27 PM   #7
km16
Sorry I dont have any pictures. I just ground on top of the caliper where it rubbed the wheel. I ground just enough so it clears I didn't have to take a whole lot off. The caliper is real thick cast I dont believe I ground enough off to damage anything. As for the speedometer it just depends what size tire you run.
Old 11-12-2012, 12:36 AM   #8
NONHOG
NONHOG's Avatar
So would the 05 wheel in 17" be the same as the 08 17" as far as offset?
I have a buddy with an 05 and he wants my old winter tires. P245/70r17.
Should they fit?
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
