Old 11-06-2012, 04:40 AM   #1
Cumminpwr11
Southern Nevada Coal Roller
Towing capacity on 3/4 ton burbs? 4x4 of course!
I am wondering what was the tow rating on 3 door burbs? I know that they aren't really effecting me cause I am sitting on a dodge 1-ton frame that is rated for 16k lbs but I would like to know where the truck was rated. I think my largest standard trailer is 9500lb fully loaded.
I just want my ducks in a row for that one time a state trooper wants to bust my balls.
Chris
Chris
72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo.
36 Chevy P/U rat rod project. 4bta cummins
Cumminpwr11 is offline   Reply With Quote
Old 11-06-2012, 02:20 PM   #2
vectorit
What?
vectorit's Avatar
Re: Towing capacity on 3/4 ton burbs? 4x4 of course!
I don't have anything handy as far as the 67-72 Suburban K20.
But 9600 is the average number I have seen for newer K20 Suburbans.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-11-2012, 05:58 PM   #3
capev86
provided you have all the options (big engine, auto trans, etc).
1/2 ton: 5500 lbs
3/4 ton: 6000 lbs
technically, my max tow rating in my 72 Burb C20 (307, 3 on the tree) is 2000 lbs. that was before i swapped the 4.57 gear for a 4.10. i put a Q-jet on it in place of the 2 barrel and plan to tow my 71 Holiday camper that weighs 6k loaded. if i do any cross country trips i will really need to install my 406sbc with a fuel injection setup (to handle high altitude).
capev86 is offline   Reply With Quote
Old 11-11-2012, 10:29 PM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Make sure your registration is up to the weight as well as the tire/wheel weight rating and you'll be fine.
I just bumped my burb up to 16000 just in case I need it (6000 for truck and 10k for trailer).
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
