Old 06-02-2003, 06:38 PM   #1
stony
disc brake conversion
Ok i know this has probably been asked a million times.... i used the searched and couldnt narrow it down to specifcally offers a disc brake conversion So thats my question what options do i have out there for disc brake conversion on my 69 GMC. I woull dalso like some info on power sterring upgrade also
thanks for your help
Stony
stony is offline   Reply With Quote
Old 06-02-2003, 07:02 PM   #2
JBARTGMC-10
swap a 73 to 80 front crossmember if you have the motor out it is real easy iam in the middle of this swap my self if you use all the parts and pedal from doner truck its should work i have been told
JBARTGMC-10 is offline   Reply With Quote
Old 06-02-2003, 07:10 PM   #3
onetoncrewcab
One of my kids. Cute eh?
onetoncrewcab's Avatar
Yep. Same here. I'm using an 86 Chev Suburban for the donor. Taking the whole engine cradle assembly. I think the power steering gear will bolt on too.
I'm not sure what I'm going to do with the rear axle yet. Someone on the board posted that I can just remove the axle shafts from the housing and switch them (I want 5 lug instead of the 6 lug). But others have said I will have to switch the whole axle assembly which means I need to buy new axle mounts to weld on the sub axle. If the axle shafts are the way to go, I then need to find the ratio of the rear end in the truck.
Mike
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did.
John 3:16
2006 Chevy HHR
2000 Dodge Durango
1985 Jeep CJ-7
1970 Chevy Pickup
onetoncrewcab is offline   Reply With Quote
Old 06-02-2003, 07:24 PM   #4
Low68
Low68's Avatar
I bought a kit from Early Classic Enterprises. I think their kit costs around 800 and includes everything you need. I bought the five lug with the drop spindles, but you can get either that or the six lug. You can also get stock height spindles if you don't want to lower it. I would highly recommend their kit. I was vary happy with it. I also converted my rear axles to five lug for more selection in wheels. I put rear discs on, but I think I could have used later model brakes off of a 72 I think. I bought axles from Ricks pick up parts that had been welded and redrilled to five lug. They were allright. One of the welds started to come out when I was putting the studs in, but other than that, they have worked well. I think ECE sells axles now also. I would give the guys at Early classic a call and get some info from them even if you don't buy their kit. They are vary knowledgable. I think most if not all of the vendors on the board also sell kits, and who knows, you may even get a discount? Good luck.
Low68
Build Thread
Low68 is offline   Reply With Quote
Old 06-02-2003, 10:51 PM   #5
Kid
Kid's Avatar
I second the ECE company. I bought their front disk conv. kit with droped spindles. Was a very easy install. (kit costs about $650.00) Also bought thier five lug axles, was a simple R&R. Pop the rear cover off, pull the c-clips, and out comes the axels. Kit came with new drums also.
Kid is offline   Reply With Quote
Old 06-03-2003, 12:14 AM   #6
dinnut
dinnut's Avatar
classicperform.com gonna get my front and rear kit from them...
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
