Old 11-14-2012, 01:45 AM   #1
bloodybigblock
bloodybigblock's Avatar
Rear disc brakes? S10 rear end. I'm confused
If I have 6 lug drum brakes in the rear, do I have to have 5 lug axels to order 5 lug brakes? I do not know very much about brakes. I can get a 2002 blazer rear end with discs, how hard would it be to make that rear end work on my 67 coil spring rear end? I can buy 5x4.75 front rotors. Maybe someone can help me.
bloodybigblock is offline   Reply With Quote
Old 11-14-2012, 02:09 AM   #2
bk2life
Re: Rear disc brakes? S10 rear end. I'm confused
what are you trying to do?
an s10 rear end is too narrow for a fullsize, unless you are going to tub your truck with 15 inch wide wheels..
if you are trying to add rear disc brakes to your axle, then get a disc brake kit and bolt it to your axle.
if you are trying to do something else, please explain as i am a bit lost..
bk2life is offline   Reply With Quote
Old 11-14-2012, 02:23 AM   #3
bloodybigblock
My truck is a stepside and i plan on running 11/12" wide wheels and dropping is 6" so i need them to clear. I seen a guy run a blazer rearend to do exactly what im trying to do. It seems like it would be cheaper to do this vs narrowing my rear end and buying a rear disc brake kit. What would it take to use the blazer rear end with my coil spring suspension? My other question was if i order a 5lug disc brake kit for my lug rear end, would i also have to order 5 lug axels? If that makes any sense.... lol, thanks
Old 11-14-2012, 10:45 AM   #4
MAK191
I'm Not sure sure about the s-10 axle strength but there are axle mount kits. I POL has them and it includes the trailing arm perches and a track bar. Of course you would have to remove all of the brackets on the axle and weld on the mounts.
MAK191 is offline   Reply With Quote
Old 11-14-2012, 02:49 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Rear disc brakes? S10 rear end. I'm confused
S-10 5 lug axles are smaller than a C=10 5 lug axles. The s-10 is 5 lugs but the circle they make is 4 3/4" where a C-10 is 5" circle. If you bought the brakes for the C-10 they will not fit the S-10 axles.
If the rear end will go under the truck as you want all you will need is a set of wheels to fit a s-10 are run adapters.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
