Semper Fi!!!
Anyone running rim adapters?
I want to run my 16' zq8s but there for s10s, anyone ever use rim adapters?
Brandon... "IT ONLY TAKES EVERYTHING YOU GOT!!" Semper Fi
#2 | |
"Oh well, it's a driver."
Re: Anyone running rim adapters?
I know it's doable -- I've seen a 454ss on Corvette wheels before, which is the same 5x4.75 bolt pattern as an S10.
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E ![]() Quote:
Semper Fi!!!
How far they stick out? That's what I'm worried about
#4 | |
Corvette wheels look good...but I'm not sure if there are backspacing differences between vette and S10.
I have done this before. I took a set of 20" Boss wheels from my 4-door Blazer and put them on my 98 X-cab. I used 1" adapters. If I was to do it again I would use 1-1/4" adapters. In oder to run the 1" adapters I had to trim the stud length. Something I did not want to do, but I already had the adapters. Unfortunately I no longer have the 98 so I can't help you with offset/backspacing questions.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
| Bookmarks |
