700r4 question???
So I picked up a recently rebuilt 700r4 for a price I couldn't pass up. Been wanting to do this swap since I bought my truck in Feb. My question is, is there a difference in the tail housings between mechanical and electric speedos? I've searched on here, and seem to get different answers. Some say the same, just switch out the guts, some say different, replace it.
'67 C20 LBW |
![]() Join Date: Oct 2004
Re: 700r4 question???
You can put a mechanical speedo in the housing.
![]() Join Date: Sep 2011
Have this one bookmarked for when I make the leap. Almost everything you can think of about the swap.
http://67-72chevytrucks.com/vboard/s...ad.php?t=33266
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
Thanks guys!!
'67 C20 LBW |
http://www.transmissioncenter.net/sp...n_______va.htm
Most applications need a 15 tooth Gray drive gear, The guys above are out of 15 tooth gears, But TCI makes them. http://www.summitracing.com/parts/tci-880018/overview/ |
Simple swap I did it on mine. Take the rear housing off to access the reluctor wheel. I had to cut mine off with a cutoff wheel. Once it's removed take your new mechanical gear and clip and slide onto shaft then reinstall your tail housing with new mechanical connection and done.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
| Bookmarks |
| Tags |
| 700r4 swap |
