Project Heaven in my 67!!!
Parting 71 LWB C10 BB 2WD
So things have changed again, and I have decided that instead of installing the BB in my 67 I am going to go the LS route eventually so I am parting this entire truck to try and put some money towards the motor that I want in the 67.
Truck is a factory BB truck with Air Conditioning... The truck no longer has a bed or drivers side door on it... So for starters I will post a few prices so as to keep inline with the rules... If you see something you need let me know and we can work something out. All prices are plus shipping and of course are always "or best offer", would rather not ship the big stuff but again we can work something out if need be... 402 BB - $700 no carb TH400 w/yoke - $350 front 5 lug disc brake suspension - $150 Power steering Gearbox - $75 Power brake booster w/Master Cylinder and Prop valve - $50 cab w/title - $100 (needs outer rockers at a minimum most likely inners too) 5 lug rear axle - $150 (I dont know the ratio but will look into that tonight) fiberglass rollpan for fleetside bed - $25 if you need better pics of anything just let me know... |
VA72C10
![]() Join Date: Mar 2008
Re: Parting 71 LWB C10 BB 2WD
Exhaust brackets that mount to the frame? Heat shield on pass side firewall? Trans linkage w/frame bracket and mount to tranny? Steering column? Frame brackets, clamshells, and rubber for engine?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
![]() Join Date: Sep 2011
2nd for the exhaust brackets, complete 2 pc driveshaft
1967 C10 SWB Owner - Rustbelt Restorations |
prices on each of the following shipped to 58265.
-spark plug heat shields -oil pressure line (from block to guage) -power steering brackets, remote resivoir and hoses. -crank, water pump, p/s pulleys -Alternator brackets -fan shroud -rear sport bumper brackets -passenger floor heat shield Thanks, Brett. |
#5 | |
Heat shield on pass side firewall? will look tonight to see if it is in good shape, take pics for you and then we can discuss Trans linkage w/frame bracket and mount to tranny? would like to leave with the transmission if trans doesnt sell soon then you will be first inline Steering column? Non-Tilt Automatic in good shape will get some pics tonight for you I will take $40 plus the ride Frame brackets, clamshells, and rubber for engine? Would like to leave with the engine for now, if engine doesnt sell soon then you will be first in line for them |
#6 | |
Truck had an aftermarket rollpan no bumper brackets 2nd inline for the heat shield, will look tonight to see if it is in good shape |
![]() Join Date: Oct 2012
If that rear end is a 12 bolt posi and you would be willing to put it on a skid, I would be interested in it. Also, any pics of the Brake Booster, etc.?
So,, what else you got???
![]() Join Date: May 2010
We would give $100.00 shipped for the big block frame stands if no one has laid claim to them yet Thanks, Fred
Sorry, just read this whole post. Did not mean to cut in on anyone's deal...
Here are some more pics and some that were requested...
Power Brake Booster Steering Column, someone messed with the turn signal lever... should be an easy fix, but works as is... An original AM radio not sure of condition will attempt to see if it works later today $15 + shipping Rear side of AM radio The hangers are already gone or destroyed by the PO... Here is a shot of the rear of the frame More to come as I can get to it... |
#13 |
Any chance the small exhaust bracket on the pass side frame rail located just behind the trans xmember is still there?
Also are you interested in shipping the complete driveshaft, front and rear shafts with carrier bearing and xmember mount.
#14 |
To be honest I think that was the only hanger left. I will check again shortly and take a pic and make sure it is what you need. As far as the driveshaft you are second inline on it and I am up for shipping if you are willing to pay for it. The shaft is large so I am not sure what the shipping would be on it...
#15 | |
2nd on the exhaust brackets to(VA72C10), 1st on the driveshaft. The shaft can be slipped apart at the splined slip joint.(JUST MARK BOTH SIDES FOR INDEX PRIOR TO REMOVAL). Should keep shipping reasonable. I also see you listed the 400 yoke w the trans, I will need it. LMK, thx, D'
#16 | |
#17 |
I can pick the rear end up in person if its avail and 3.08
Posted via Mobile Device |
#18 |
C/10 junkie
How much for the center link with tie rods shipped to 95240 business addy?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#19 |
The rear axle is not positive traction, but I am not sure of the ratio... If anyone is still interested in it let me know!
#20 |
interested in what is on the interior. How is the AC setup?
BTW, OOH RAH and happy belated birthday |
#21 |
#22 |
depending on condition, I'd be interested in the whole A/c lot minus the metal dash and the compressor.
Interior wise, I'm interested in the A/c vents and controls. If you were local, I'd snag that seat from ya too, but shipping would kill me |
#23 |
![]() Join Date: Sep 2012
Second in line for rear sport bumper brackets,how much shipped to 33315.thanks Brian
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
#24 |
#25 |
Gentleman, I will get pics and prices up today for those that have asked about parts.
