Old 11-24-2012, 03:29 PM   #1
ZMAR
ZMAR's Avatar
8 lug to 6 on a 14blt sf
Rearend went out and I found a sf for $100 so I just grabbed it. I put it under my truck and I really love my 20" wheels I have. Is there a cost effective way to change over to 6 lug? I would rather not have wheel adapters but I might have to go that route
71 c10 swb
ZMAR is offline   Reply With Quote
Old 11-25-2012, 08:53 AM   #2
BigBlocksRule
Re: 8 lug to 6 on a 14blt sf
Hubs are different size...you'll have to swap axles. There are two different lengths - 2WD is narrower than 4WD.
BigBlocksRule is offline   Reply With Quote
Old 11-25-2012, 01:03 PM   #3
ZMAR
ZMAR's Avatar
I've got a 95 that is 4wd. Would those axles work?
71 c10 swb
Old 11-25-2012, 03:48 PM   #4
BigBlocksRule
Nope, those are the wider ones, you need a 2WD for a straight swap.
Old 11-25-2012, 06:30 PM   #5
ZMAR
ZMAR's Avatar
So a 99-up 6 lug out of a 2wd?
71 c10 swb
Old 11-25-2012, 07:13 PM   #6
ZMAR
ZMAR's Avatar
Lol what an idiot. The 95 Z71 has a 14blt in it. It's nearly stripped except tranny and rearend. Well just tranny now!
71 c10 swb
Old 11-25-2012, 07:15 PM   #7
clinebarger
Just buy new axles, Because of the nature of SF axles to wear where the bearing rides......http://www.ringpinion.com/b2c/Produc..._Gear_and_Axle
clinebarger is offline   Reply With Quote
Old 11-25-2012, 09:13 PM   #8
BigBlocksRule
Don't let that wide one go, it's a great upgrade for Tahoes/Suburbans. It's the same width as the front on 4WD vehicles versus a few inches narrower as they come from the factory, makes the track widths almost exactly the same...plus it's a great strength upgrade!
Old 11-25-2012, 10:16 PM   #9
ZMAR
ZMAR's Avatar
Is the one out of the 3/4 the one I need to use? Or the one out of the z71?
71 c10 swb
Old 11-26-2012, 08:02 AM   #10
BigBlocksRule
You'll want to use the one out of a 2WD since that's what you have. The wider one will be better for a 4WD.
Old 11-26-2012, 08:17 AM   #11
ZMAR
ZMAR's Avatar
I'm sorry I wasn't clear in my first post. This rearend is going in my 92 that is 4x4, not one of my old trucks. The 3/4 8lug came out of a 4x4 and the 6lug is coming out of a 4x4. I guess they are the same width, just different gears and axles correct?
71 c10 swb
Old 11-26-2012, 08:59 AM   #12
BigBlocksRule
Are they both 14-bolt? I think all the 10-bolt are all narrower than the wide 14-bolter.
Check sleazebay, you might be able to find some 6-lug axles for the 14-bolt since it'll fit the 4WD better.
Old 11-26-2012, 10:26 AM   #13
ZMAR
ZMAR's Avatar
Yes both are 14 bolt. One is 6lug and the one I bought is 8lug
71 c10 swb
