Old 12-03-2012, 10:19 PM   #1
vjjack04
vjjack04's Avatar
90 aftermarket dash info
I have a friend that swapped the motor in his 89 chevy which had a throttle body for a 383 with a carb. He also removed the computer and went "old school" but cannot find a good way to put aftermarket speedo and tach in the dash/gauge area.....anyone know of an aftermarket set up to do such a thing?
vjjack04 is offline   Reply With Quote
Old 12-03-2012, 11:31 PM   #2
Mr_Rich
Mr_Rich's Avatar
Re: 90 aftermarket dash info
If he's still using a 700R4 you can swap the elec. speedo sensor for the mechanical cable adapter at the tail housing. A tach should be simple since there is already a spade terminal off the coil. Pick up the tach signal there. It's an idea anyway...
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
