Old 12-06-2012, 02:37 AM   #1
BrutonLS1
BrutonLS1's Avatar
Question about Brakes
Hey guys,
I'm looking for a stock proportioning valve for a 68 gmc, drum brakes.
this is all I found in the LMC catalog, any ideas on the exact one I need and where I'd get it?
-Bruton
1968 GMC long bed 5.7/700R4
--I'd rather push a Chevy, than drive a Ford.--
BrutonLS1 is offline   Reply With Quote
Old 12-06-2012, 02:51 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Question about Brakes
Proportioning valve is only used with front discs because they require higher line pressure than drum brakes. With all drums like on your '68, no prop valve is needed. All it uses is a block (no valve inside) that connects all brake lines to the master cylinder.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-06-2012, 03:05 AM   #3
FirstOwner69
FirstOwner69's Avatar
Here's an eBay link to what you need.
http://www.ebay.com/itm/200615292156...84.m1423.l2649
The Right Stuff (www.getdiscbrakes.com) or Inline Tube probably has them also.
FirstOwner69 is offline   Reply With Quote
Old 12-06-2012, 10:06 PM   #4
BrutonLS1
BrutonLS1's Avatar
Thanks a lot for the info! I was bleeding my brakes and I couldn't get the back to bleed, it wouldn't get fluid to the bleed screws. I thought it was the hose, so I replaced it, unfortunately it didn't fix it. I then removed the line from the *dist valve, and no fluid would come out. Now that I know there's no valve inside, could I just blow it out with an air compressor and be good to go?
-Bruton
Old 12-06-2012, 10:28 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Worth a try, depending on what the blockage is. One more thought, the one pictured in FirstOwner69's ebay link has the switch for the dash light.... assuming yours does also, remove the switch and see if that is somehow blocking fluid flow. In fact, before you remove it -- do you have a dash warning light, and is it on? If so, try pressing very hard on the brake pedal a few times. It may center the switch, which just might let flluid flow through the distribution block.
- Mike -
RIP El Jay
Old 12-09-2012, 07:23 PM   #6
BrutonLS1
BrutonLS1's Avatar
I do have a brake light, and yes I recently plugged that back in after my engine swap. Maybe this is my problem?? it has to be set in an exact position? It comes on every now and then, sort of at random times.
-Bruton
Old 12-09-2012, 10:11 PM   #7
GMCJOE
GMCJOE's Avatar
Get a hand pump brake bleeder and pull the fluid back thru the lines. I had the drivers front rubber line blow out on me going down hill and ran thru a stop sign before I got it stopped. It was scary. Anyway, that way the only way I could get pressure and fluid back in the brakes.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 12-19-2012, 10:39 AM   #8
70blackfish
do you still need this block, Im taking one off my 69 truck soon.. you can have it....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 12-19-2012, 11:01 AM   #9
CC69Rat
CC69Rat's Avatar
LS1 with drum brakes? If you got the GO, you need the WAHO too (?) Is it power drum?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-10-2013, 10:07 PM   #10
BrutonLS1
BrutonLS1's Avatar
No just regular old drums. Haha
I plan on converting to discs all the way around eventually, but like everything else, it's just time and money.
I bought new hardware, cylinders, shoes, hoses, drums, and master cylinder.
My line fittings in the front turned out to be rusted solid and also rounded off, so I had to cut them. In the LMC catalog it looks like you have to buy the complete brake line kit for drums, for a pretty penny too. Does anyone know where to get pre-bent lines for the front only?
-sorry for the delay guys
-Bruton
Old 03-10-2013, 10:11 PM   #11
BrutonLS1
BrutonLS1's Avatar
I sure appreciate that offer!
Sorry for the late response, not sure if you still have it or not
-Bruton
Old 03-10-2013, 11:37 PM   #12
FirstOwner69
Try The Right Stuff (www.getdiscbrakes.com) or Inline Tube (www.inlinetube.com) for the lines you need. I had excellent results with The Right Stuff.
