Old 12-06-2012, 02:53 PM   #1
Kool K5
Kool K5's Avatar
Question Help! k20 rotor removal with sears/selectro hubs
Hey guys,
I'm trying to take the rotors off my Blazer but am having a hard time.
Truck is a 70 Blazer with 3/4 axles. 10 bolt up front.
I've removed the locking hubs but cannot seem to get to (or even see) the nut to take off the rotor. It has sears/selectro hubs on it and when I look online, all the pictures I find are different.
Its a possibility that I'm half stupid though LoL
70 Blazer 4x4 305/sm465/np205
80 Buick LeSabre Limited
72 Honda CB350F
77 Honda Cb750K
00 Ducati Monster M900ie
Kool K5 is offline   Reply With Quote
Old 12-06-2012, 02:55 PM   #2
Kool K5
Kool K5's Avatar
Re: Help! k20 rotor removal with sears/selectro hubs
Here's some pics
72 Honda CB350F
77 Honda Cb750K
Old 12-06-2012, 02:59 PM   #3
steelhorse
steelhorse's Avatar
Is there a snap ring between the hub and the selector? Could be a round one.
steelhorse is offline   Reply With Quote
Old 12-06-2012, 03:00 PM   #4
Kool K5
Kool K5's Avatar
Not sure if this is a diagram for my axle.
72 Honda CB350F
77 Honda Cb750K
Old 12-06-2012, 03:01 PM   #5
Kool K5
Kool K5's Avatar
I can't see any snap rings in there. When I go back tomorrow I'm going to clean the crap out of it with brake clean so I can see in there better.
72 Honda CB350F
77 Honda Cb750K
Old 12-06-2012, 06:15 PM   #6
airdale94
airdale94's Avatar
I think you can push that hub in and then there's a snap ring on the shaft.
Also once you get the rotors off you pound the studs out to seperate the rotor from the hub.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 12-06-2012, 08:45 PM   #7
CrewCab59
CrewCab59's Avatar
You should have 2 snap rings.
1. The large ring where the hub and the spine gear come togther.
2. The small ring where the axle shaft and the drive shaft gear.
see pic below
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 10-14-2017, 09:27 PM   #8
MadMike1989
Unhappy Re: Help! k20 rotor removal with sears/selectro hubs
see pic below
I have the same setup. Do you know how to remove it????
MadMike1989 is offline   Reply With Quote
