Old 12-11-2012, 09:12 PM   #1
Emmaschevy
Emmaschevy's Avatar
Question Black silicone removed?
previous owner siliconed whole windshield in...i have new windsheild and new gasket. How do i remove all that old crap off cab and window channel? Razor? Solvent? What works best.. thanks guys. By the way its an 82 short bed. Thanks
Emmaschevy is offline   Reply With Quote
Old 12-11-2012, 09:43 PM   #2
stepsideguy82
Re: Black silicone removed?
if you have a die grinder could use a soft wire wheel or wire brush to get most of it off then just hit it with some goof off and clean it real well then paint the area to prevent rust
stepsideguy82 is offline   Reply With Quote
Old 12-12-2012, 09:19 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
better make sure you have a spare windshield first... when its silicone in removal is tough without cracking it up
razorblade on the glass to remove silicone if you get it out ok and then as described above for the metal side
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-12-2012, 10:08 AM   #4
pontgta
pontgta's Avatar
Silicone will rust out metal.... I would try solvent before the grinder(goo be gone...thinnner)....unless you are going to paint it..
pontgta is offline   Reply With Quote
Old 12-12-2012, 11:26 AM   #5
1774btcrew
1774btcrew's Avatar
I would suggest trying an eraser wheel in a die grinder. I have used it on stripes so it might work on silicone. It won't hurt the paint.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 12-12-2012, 12:35 PM   #6
buffle
buffle
buffle's Avatar
My 87 was the same way , what I found after removing black goo was scary. There was rust everywhere in window channel. But actually removing the goo wasn`t too bad , after the initial cut it peeled out fairly easy.
Life is like a roll of toilet paper. The older it is, the faster it is used up.
buffle is offline   Reply With Quote
