12-31-2012, 08:31 PM | #1 |
vacuum guage purpose
I recently purchased a tach dash w vacuum guage from e-bay. I was wondering what the purpose of having one was? I was also needing to know what you hook it up to? what type of trucks did they come in?
12-31-2012, 08:41 PM | #2 |
Re: vacuum guage purpose
Darren, Techs will use a vac gauge to tell the basic condition of an engine by glancing at it. Also the vaccum will tell the ecoomy of an engine as in cruise mode the vac is high as you open the throttle the vaccum decreases. You can also set the idle mixture of your carb by them by turning in the idle screws until the gauge reaches its highest point then stop and do the other side. when you move the idle screws in and out it will move the vaccum up or down so the goal is to obtain the highest reading possible. The same goes for normal driving if you try to keep the gauge reading as high as it can be your mileage will be at its best. But you should keep in mind that tuning is gonna be hard to do with the smaller size of the guage that we have in our trucks. They are quite useful and fun to boot. If Iam not mistaken the hose will need to be hooked into manifold vaccum, being that it is under the throttle plates of the carb. Jim
12-31-2012, 08:51 PM | #3 |
this might help: http://www.secondchancegarage.com/public/186.cfm
Have seen it passed around in a few other posts. It is often used IN the cab as a "let off the gas, you're getting horibble gas mileage" gauge, but - in these trucks, kinda unavoidable. But a handheld vac is most useful for tuning under the hood when jimmying carb settings, etc. I installed a Pontiac Vac Gauge in my 66 and went thru the "how do I hook this thing up" question as well. Must be hooked to a "full time" vac port. So, as hugger points out, past the throttle plates is correct. |
12-31-2012, 09:00 PM | #4 |
Good info guys. thanks. But what trucks came stock w them?
12-31-2012, 09:02 PM | #5 |
Member #1049
12-31-2012, 09:06 PM | #6 |
The gauge was used on medium duty trucks with Hydrovac brake boosters.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-31-2012, 09:22 PM | #7 |
I had one in my old motorhome. Mostly it just scared the crap out of me any time I touched the accelerator pedal.
12-31-2012, 09:28 PM | #8 |
They register the magic..
J.
1972 Custom Deluxe Highlander C20 1971 Javelin SST New Project 1971 Demon 340 1969 SS El Camino 1968 SS RS 396 Camaro 1967 Barracuda Formula S 1965 140/4sp Corvair Monza Convertible Sorry, but I don't do Fords. |
01-01-2013, 11:13 AM | #9 |
thanks for all the info.I cant wait to get mine in and see how well it works.
01-01-2013, 01:02 PM | #10 |
My Carbon Footprint
Tach dashes with vacuum gauges are know for shorting out and causing a cab fire. This is why they were discontinued. I am happy to help you out of your problem though. I will give you $50 for it in working condition so I can use it for parts! ;o)
01-01-2013, 01:51 PM | #11 | |
70+ ( Old Skool Club )
Does ths mean it wasn't available as an option on C10's-20' and 30's ? Posted via Mobile Device
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-01-2013, 02:16 PM | #12 |
Not as an RPO that I have been able to find. There is code Z72 Vacuum Reserve Tank, Gauge and Warning Light. But again this is a Medium Duty Truck option.
01-01-2013, 03:30 PM | #13 |
I thought there was somebody on here with a manual throttle and vac gauge (no tach) in a C10. I *thought* it said that it was factory. That was a while ago though.
01-01-2013, 05:01 PM | #14 | |
In the medium duty trucks it was an important part of the braking system to have vacuum on call and lots of it for the Hydrovacs, hence the gauge for trending and the light for a "too late dude" warning. If there is a light duty that has it called out for on the SPID I would like to see it. The only possible C30 application I can think of might be a 14K GVW C30
01-01-2013, 11:59 PM | #15 |
I dont think I ever heard that one before.Has any one else heard of this?
01-02-2013, 12:18 AM | #16 | |
Roadtrip!
I think he is yanking ya trying to get your dash for $50... All in good fun i am sure...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-02-2013, 12:37 AM | #17 |
My 72 has a vac guage. Looks factory, on the right side of the column.
01-02-2013, 12:38 AM | #18 |
My Carbon Footprint
My bad.....totally messing with you because the vacuum gauge is something that I think 99.738% of us would love to have. Heck, even if it didn't work it would balance out the gauge cluster!
01-02-2013, 01:18 AM | #19 | |
But if yours is listed on the SPID I would very much like to see a picture of it.
01-02-2013, 01:22 AM | #20 |
you aint rite for that...you had me doin research on the subject,,,I am paranoid about cab fires. I did see a truck awile back that had a tach and had a cab fire..
01-02-2013, 01:38 AM | #21 |
My Carbon Footprint
Vacuum is air....would be hard to have a cab fire due to an air leak. LOL My bad still!
Many on here will agree that I aint right for a lot of reasons. |
