01-04-2013, 12:04 PM | #1 |
Junk Yartist
Eastwood vs. HF Bead rolller
Hey all, I have been saving to buy a home bead roller for some time now, and have been looking at the HarborFreight one and the Eastwood one. The HF is about 80 more than the Eastwood, but it comes with a shearing die also. Does anyone have experience with either?
HF pro-sheering die pro-18" throat con-price con-driving distance Eastwood pro-price pro-shipping con-no sheering die con-17" throat
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
01-04-2013, 01:30 PM | #2 |
Re: Eastwood vs. HF Bead rolller
Check with these guys, some of the most amazing talent I have seen.
If they don't know, it probably can't be known when it comes to metal shaping. http://www.metalmeet.com/forum/index.php
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
01-04-2013, 08:38 PM | #3 |
Find a answer let us know here.
01-05-2013, 01:03 AM | #4 | |
Junk Yartist
I will for sure!
01-05-2013, 10:36 AM | #5 |
Hand Crafted C-10
Me too! Didn't look around much but the site looks huge.
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
01-06-2013, 01:48 PM | #6 |
Just bought the HF version. Sale price plus 20% off. Depends on the cashier,
she asked me if I wanted to use it. (uh sure!) So far its a bit worse than I expected. Seems to have enough run out in one or both of the shafts that its binding a little when turning by hand. (no lever) I de burred the gears with a hand file and that helped a bit. Dial indicator verified my suspicions. I'm going to put it together anyway and test it out. Might be a non issue with hand crank. You could also search the HAMB for some pretty cool mods on these. I like MetalMeet but AllMetalShaping is smaller (a plus for me) Good luck !
"I feel the need for speed!"... as soon as I am done with my nap. |
01-06-2013, 01:56 PM | #7 |
Junk Yartist
NONHOG, that's good to know about the HF roller. About the only thing that I have from HF that I love is the 9 dollar set of step drill bits. I drill a pilot hole and they work great. Did your roller come with the sheering mandrel?
01-06-2013, 02:00 PM | #8 |
Pro.........Harbor does shipping also
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
01-06-2013, 03:02 PM | #9 | |
Most all the reviews about the basic HF unit have been the same beef it up and its fine. Mine and 1 other I've read about the shafts were out. For me HF is only 20 minutes away.
01-06-2013, 03:11 PM | #10 |
try it out get back to us with your findings...I would buy one
01-06-2013, 03:18 PM | #11 |
i had a harbor frieght beadroller that i used for well over 10years on a ton of projects// not at all the best quality but for the price it could not b beat// the whole trick to using it is to layout your pattern before hand and to just slightly run it thru with slight pressure and to make 3-4passes increasing pressure 1/2- 3/4 a turn each time until you have the finished product
never did have any luck with the socalled cutoff mandrells
01-06-2013, 05:49 PM | #12 | |
Junk Yartist
01-07-2013, 10:10 PM | #13 |
Tot Roddin'
Keep us posted on the outcome when you receive/use the Eastwood one.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-17-2013, 04:35 PM | #14 |
jbclassix, looks almost like the Eastwood main frame is thicker?
care to measure? I'll do the same. Thought it would be good for future buyers to know. So far messed around only a bit. Cutter seem to be a waste of space. Need to make a wheel ASAP and get rid of the crank.
01-18-2013, 02:48 AM | #15 |
01-19-2013, 12:55 AM | #16 | |
Junk Yartist
01-19-2013, 01:50 AM | #17 | ||
Could see how there style could be "clicky" Quote:
Looking forward to your reviews!
01-19-2013, 10:48 AM | #18 |
Junk Yartist
NONHOG post away! It's why i started this thread so anyone can post their opinions pro or con of this type of bead roller... and maybe some how-to's
01-19-2013, 02:15 PM | #19 |
Felt kinda like walking into the wrong bar, you get that feeling to just keep walking and slip out the back.....[turn around and run out the front, they might chase you]
01-26-2013, 11:52 PM | #20 |
Junk Yartist
I drove over to Bakersfield yesterday and picked this guy up. I will start another thread to write some reviews and tips on it. I am still saving for the Eastwood bead roller. Sorry for the bad picture.
01-26-2013, 11:59 PM | #21 |
Nice!
