Vent window rubber install?
Can you tell me the easiest way to get the new weatherstrip into the channel of the vent window bracket?? soap, armorall - what a pain. Thanks for your asssitance.
![]() Join Date: Dec 2012
Re: Vent window rubber install?
The way I did it was bring it to a small body shop around the corner. They did all of the door weatherstrip for $200....I supplied the parts.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#3 | |
Carpe manana
![]() ![]() Join Date: Dec 2010
I got a tube of water based KY jelly, which made it an easy job. What's a real bummer is after all the effort to rebuild the vent windows the repro seals started cracking within 6 months of being exposed to the sun.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Thank you much! Appreciate the info guys.
Precision Restoration Parts has a youtube video they made installing those
Thank you jd.
Tech Help
![]() Join Date: Apr 2012
Haven't done the 67-72 yet but we're planning on it. We did 73-80 which are similar and will give you the idea on how to tackle it.
Let me know if you have any questions! Derek
PRECISION Updates Subscribe --->Installation Videos Follow ------->Instagram Like---------->Facebook |
#8 | |
Carpe manana
#9 | |
Tech Help
What brand is this cracking happening with? Derek
#10 | |
Carpe manana
Sorry I cant recall which brand. For what it's worth, these were purchased by a board vendor who I believe sells the best available products. It's disappointing to say the least after expending the effort to rebuild the vent windows to have them crack so quickly. Consequently, I went through a lot of effort and $$ to obtain NOS pieces for my K20 build. Another area you may wish to investigate are the gaskets for door handles and locks. The reproduction pieces also quickly dissolve in the sun (NOS examples are now $45-55). The originals were more of a gasket material than rubber. This is a possible area for growth for Precision: if you can match OEM quality you'll easily corner the market. Good luck, Pete
