06-11-2003, 02:18 PM | #1 |
Van Tilt
i have a van tilt in good usable condition came out of I THINK 78 1ton van $120 shipping included to the 48states only if interested give me email address and i'll send pictures
06-12-2003, 09:31 AM | #2 |
69 chevy C20 307/3 speed 4.10 posi. |
06-12-2003, 07:41 PM | #3 |
forgot to mention this has a cruise-control in the turnsignal lever, but it's just a 1wire deal to disconnect[or you can use it for a switch for a horn or setup a set of spots that you can use for flickin on and off with your fingertip!! disconnecting the 1wire and you can use the regular turn lever
06-12-2003, 08:00 PM | #4 |
its all about the +6 inches
Not to jump on his thread, but the cruise controll switch can actually controll 2 seperate items. It is a 3 position switch, off, 1/2 way in (one item) and all the way in (second item).
Also, with the steering wheel off, you can remove it and all its wireing and install your stock turn signal switch very easily. |
06-12-2003, 08:57 PM | #5 |
hey i just looked again and longhorns right !! but you dont have to change the turnsignal switch just the lever to a normal lever if you don't want the cruise lever
