![]() Join Date: Nov 2007
4x4 Spicer Lockout, spindles, hubs
I have some leftovers from my front axle rebuild on a 72 dana 44. I will list what all is here since it may be hard to see in the picture.
1. Spicer lockout that is slightly scratched, working 1. Spicer lockout heavily scratched, center broken, but still working 2. Inner lockout gear locks (not sure what there called), both work 1. push in device 1. screw down plate 1. axle snap ring 1. outter c ring 1. spindle nut washer 2. inner spindle nuts 1. outer spindle nut 9-10 lockout screws 2. spindles. 1 has some slightly damaged threads, could be easily chased/filed to make work. 2. Hubs, both had holes drilled for grease fittings, I have welded one shut, other still needs welded shut. *cliffs notes* enough to make one side work, with some left overs. How does 25 plus shipping sound? Its gonna cost a fortune to ship due to weight I am guessing.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
| Bookmarks |
