Old 02-25-2013, 01:13 PM   #1
Jimbabwe
Jimbabwe's Avatar
I6 throttle
Does anyone know how to get this pin out of the manifold? I thought as soon as I took the cotter pin off the side of the throttle mechanism the whole thing would slide out. I've tried whacking it and that does absolutely nothing.
I want to swap from the rod throttle assembly to the cable version. I got the proper brackets from a board member , which use a bolt instead of this "pin", and attach from the other side.
Jimbabwe is offline   Reply With Quote
Old 02-25-2013, 01:15 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: I6 throttle
It's just seized. It should tap out like you're thinking. You might have to get medieval on it.
Old 02-25-2013, 02:41 PM   #3
Jimbabwe
Jimbabwe's Avatar
Re: I6 throttle
Ahh, cool. I thought so. Thank you, sir. BFH it is!
Old 02-25-2013, 02:48 PM   #4
Tx Firefighter
Re: I6 throttle
Just don't mushroom it or you'll never get it out of there. Maybe use a brass punch if you have one.
Old 02-25-2013, 03:15 PM   #5
blkcorvair
blkcorvair's Avatar
Re: I6 throttle
drill it
blkcorvair is offline   Reply With Quote
Old 02-25-2013, 06:09 PM   #6
Jimbabwe
Jimbabwe's Avatar
Re: I6 throttle
"Check", on the brass punch. I've seen mushrooming done by an over-eager gorilla or two in the past.
Drilling might be next.
Someone told me to heat the manifold and apply cold to the pin. Torch for the manifold, but what for the cold? Ice cubes? I'm not taking my motor apart to stick this in the freezer!
Old 02-25-2013, 06:16 PM   #7
Tx Firefighter
Re: I6 throttle
If you'll heat that raised lump where the pin sits, I'd about bet it will come out with hammer and punch. Heat does wonders. You'd be hard pressed to apply any appreciable amount of cold to it.
Old 02-25-2013, 10:36 PM   #8
pritch
pritch's Avatar
Re: I6 throttle
A good source of cold are those spray-air cans that you use on your keypads. Turn them upside down so the fluid comes out and it's really cold. It'll knock the bottom out of a thermometer!
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 02-25-2013, 10:39 PM   #9
Jimbabwe
Jimbabwe's Avatar
Re: I6 throttle
Got those too.
